3 Thought Experiments on Light: No Photons or Waves
  • Thread starter Thread starter timharvey027
    Photons Waves
The discussion presents three thought experiments challenging conventional views of light as either photons or waves. The first experiment argues that a spherical light source emits light in such a way that it creates an illusion of spikes from a distance, suggesting limitations in how light is perceived. The second experiment compares light's behavior to a ping pong ball, questioning whether light possesses momentum and how it behaves differently for observers in motion. The third experiment involves a setup of mirrors reflecting light, raising the issue of why light does not continue reflecting indefinitely, highlighting energy loss and the nature of photon interactions with materials. Overall, these thought experiments provoke deeper inquiry into the fundamental nature of light and its behavior.
timharvey027
I would like to invite your comments on three thought experiments. The first i suggest demonstrates that light cannot be either a stream of photons nor a wave. The second questions if light can also have momentum and the third asks why a theorectical truth is not observed.
Here we go, 1. Consider a small light source which is completley spherical. Light is emitted from it, imagine for a moment that light emitted is in straight lines almost like a million laser beams being emitted from a shepherical pin head. Now because the surface is spherical there will be a miniscular difference of a degree of the angle in which each light path is emitted. If this is refutted with the argument that light is emiitted at every angle from every point then this would mean that an infinate number of light paths and thus sources would exist ( not possible). So again because the surface from which the light is emitted is shepherical this means that to an observer a million miles away the appearance of light emiitted would be like a round pin head with a million spikes protruding from it, as you move further away from the source the distance between the spikes increases, meaning that to viewers further away those seeing othe space between the spikes and thus the source source would not be visble. More detail available if needed.
2. Imagine you are on a train bouncing a ping pong ball up and down on the table in front of you. It works.I agree that the movement of the ball will be seen differently from an observer on the platform from that on the train.
Suppose the that the bouncing ball is replaced by light traveling between two mirrors on the train representing the bat and the table top. My question is, does light have the momentum that the ping pong ball has when it leaves it's fist source. Do actual observations confirm that light will rebound to a pooint different from its emmission.
3. Imagine a set of four mirrors set within a square at 90% such that any light intoduced would reflect off of each mirror forming a square, in theory this light would continue to reflect. Further imagine that one of the mirrors is a two way mirror and that a laser beam is introduced firing at the next mirror, after some moments the two aspect of the mirror is converted back to a reflecting mirror. In theory the light beam should continue to reflect between the mirrors in a continuous square but it does not, why?
Sorry for the lack of detail i have tried to keep this short
Science news on Phys.org
A ping pong ball will only return to a position other than it's original if there is an outside force acting on it.
If it is moving with the train, inside it without any interference it will always bounce vertically. This is independent of reference point.
It only appears on a curved path due to the train moving - not because it is actually curving - don't confuse the two issues.
No, it wouldn't. You get losses with light just like everything else. It would last for a few fractions of a second before dying out once a source is removed.
Photons are constantly emitted in random directions, which over any amount of time greater than something like a few nanoseconds will effectively be ALL direction. Imagine having trillions and trillions of spikes every single second coming at you. You would definitely see a few.
And after just watching some Richard Feynman lectures over the last few days. He has said that the photons we see coming from the mirror are not the same photons that hit the mirror from the originating light source. Rather the "reflected' photons we see are new photons emitted from atoms from within the mirror as a result of the interactions/bombardment of the original incoming photons
Dave
I would like to use a pentaprism with some amount of magnification. The pentaprism will be used to reflect a real image at 90 degrees angle but I also want the reflected image to appear larger. The distance between the prism and the real image is about 70cm. The pentaprism has two reflecting sides (surfaces) with mirrored coating and two refracting sides. I understand that one of the four sides needs to be curved (spherical curvature) to achieve the magnification effect. But which of the...
