Is an Electromagnetic Wave Truly 2D or 3D in Nature?
Futobingoro
Perhaps this has already been brought up, but is an electromagnetic wave 2-dimensional or 3-dimensional?
The current "up-and-down" concept does not have me convinced. If you look at a standard spring, you can see that it is a spiral/helix. You can also see that the side of the spring resembles a sine/cosine wave. So is an energy "wave" actually just a spiralling particle acting as a photon and appears to be an "up-and-down" wave only when viewed from the side?
If true, this would explain at least two phenomena:
1. When the amplitude of a "wave" is doubled the energy is quadrupled. In the formula for area of a circle (what would be the frontal cross-section of a spiral/helix), if one doubles the radius of the circle from 1cm to 2cm he goes from pi*cm^2 to 4pi*cm^2. Clearly, the so-called two dimensional wave acts as a circle when its amplitude is altered.
2. The side-view of EM radiation shows the standard sine wave and the path of the wave. The wave has the fastest vertical motion near the x-axis and slow vertical motion near the top and bottom.
This would lead one to believe that the particle is traveling forward and backward in space relative to the side view, characteristic of spiral motion.
It is much like a ferris wheel. If you arrange yourself so that you are in-line with the wheel, the vertical speed of the cars is evident. The cars have the highest vertical motion right at 0 degrees on the wheel. Once they near the top, their vertical speed is negligable. This is proven by the fact that at only 30 degrees, the sine measure is already at .5 radii. So if the motion of the particle on display screens exhibits slower speed at the crests and troughs of the sine wave, then there must be circular motion.
If the wave is as we know it now, the particle would remain at a constant velocity on the display screen, completing a 45-->135 degree segment in the same time as a -45-->+45 degree segment.
There are some interesting implications if this is true.
-The particle would always be traveling in the same direction, only around a helix.
-Is frequency determined by the angle of the particle in relation to the helix?
-Or its velocity...
-Or both?
-Is there an attracting body which holds the photon together?
-If the photon itself is traveling at the speed of light relative to the surroundings, then what is the velocity of the particle relative to the surroundings. (vector creating a small, but important, amount of forward velocity)
Likes Paul Tronvig
An EM wave is a three dimensional object since it exists in three dimensions (or 4D if we consider special relativity).
It is an electric field vector and a magnetic field vector which oscillate about 0 sinusoidally at a fixed time period. That time period determines frequency.
Photons do not spiral because that would require a force towards the center of the spiralling (all circular motion requires a force towards the centre of the circle). Basically the photon moves in a straight line (or is likely to on macroscopic systems) because there is nothing to stop it. Macroscopically, photons do not spiral, although there is a small probability that they do.
Your question is confused. Remember, unless we measure where it goes at every point in a path, we don't know where it goes.
How can there be insufficient information to develop a spiral model if there is enough information to develop a wave model?
If we can not directly determine the activity in an EM photon, we can draw conclusions based upon observed phenomena.
This is just like the current belief in the structure in an atom.
I presented two phenomena which support my theory when I opened this thread.
And masudr presented a killer reason to reject your theory. There is no force that would make the wave go around in a circle. The point is that we know the mechanics of electromagnetism, we know how the electric and magnetic forces work and interact. Your theory is completely wrong.
This is a common misunderstanding of the standard figure. But that figure does not represent a path. It represents a vector field. Nice figures and animations that try to explain better are shown here:
http://www.cs.brown.edu/stc/outrea/greenhouse/nursery/physics/emwave.html
Not an expert in QM. AFAIK, Schrödinger's equation is quite different from the classical wave equation. The former is an equation for the dynamics of the state of a (quantum?) system, the latter is an equation for the dynamics of a (classical) degree of freedom. As a matter of fact, Schrödinger's equation is first order in time derivatives, while the classical wave equation is second order. But, AFAIK, Schrödinger's equation is a wave equation; only its interpretation makes it non-classical...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. Towards the end of the first lecture for the Qiskit Global Summer School 2025, Foundations of Quantum Mechanics, Olivia Lanes (Global Lead, Content and Education IBM) stated... Source: https://www.physicsforums.com/insights/quantum-entanglement-is-a-kinematic-fact-not-a-dynamical-effect/ by @RUTA
Is it possible, and fruitful, to use certain conceptual and technical tools from effective field theory (coarse-graining/integrating-out, power-counting, matching, RG) to think about the relationship between the fundamental (quantum) and the emergent (classical), both to account for the quasi-autonomy of the classical level and to quantify residual quantum corrections? By “emergent,” I mean the following: after integrating out fast/irrelevant quantum degrees of freedom (high-energy modes...
