Laser beams and beat frequency.
Combining two laser beams of different wavelengths can produce a beat frequency equal to the difference between the two lasers, a process known as heterodyne detection. This requires the detector to be locked to one of the oscillators, with the potential to generate harmonic waves in a nonlinear medium. Such effects can lead to significant issues in Wavelength Division Multiplexing (WDM) telecommunication networks, causing cross-talk between channels due to optical nonlinearity in fiber optics. To mitigate these problems, specialized optical fibers have been developed, but older fibers still struggle with these effects. The challenges highlight the limitations of utilizing older long-distance fibers in modern telecommunications.
Bill E
If I combine 2 laser beams of different wavelengths, would I get a beat frequency of the difference between the 2 lasers?
Thanks, Bill
Science news on Phys.org
It is possible to measure both the sum and difference frequencies (heterodyne detection). IIRC, implementation requires the detector to be 'locked' to one of the oscillators- at least, the heterodyne optical systems I used have all set one of the oscillators as the 'reference'.
You can get even more: mixing two laser beams of close frequencies: f, f+Df (Df<<f) in a real medium (a little bit nonlinear) you may get harmonic waves: f+2Df, f-Df, etc.
This effect causes lots of problems to WDM telecommuniaction networks, as optical nonlinearity in the glass used for fibres is sufficient to generate cross-talks between lambda-channels: the data in channel f+2Df are noised by cross-talk generated by harmonic beat of signals transmitted in f and f+Df.
Special kind of optical fibres had to be developed to reduce this effect, they are installed nowadays, but it is impossible to use even half of channels of WDM over 30 years old long-distance fibres, which were not aware about such effects.
I would like to use a pentaprism with some amount of magnification. The pentaprism will be used to reflect a real image at 90 degrees angle but I also want the reflected image to appear larger. The distance between the prism and the real image is about 70cm. The pentaprism has two reflecting sides (surfaces) with mirrored coating and two refracting sides. I understand that one of the four sides needs to be curved (spherical curvature) to achieve the magnification effect. But which of the...
