Electromagnetic force required to levitate an object
The discussion focuses on using homemade electromagnets to levitate an object, emphasizing the need for understanding the underlying math. The participant references the formula for the magnetic field of a solenoid, B=μo*i*n, but encounters confusion regarding units and the correct application of the number of coils. Clarification is provided that n represents the number of turns per unit length, while the total number of turns is denoted as N. A critical point raised is that the magnetic field outside a solenoid is negligible, which poses a challenge for levitation. The addition of a ferromagnetic core is suggested as a potential solution to enhance the magnetic field's effectiveness.
bks008
I'm trying to use some home-made electromagnets to lift a small object. I am a college student, but this is a personal project, so while I may reference something from a textbook, its not a homework problem.
I know that I can get some iron bar, coil it with wire, run some current through it and see if it works, but I want to know the math behind it. I know I'm trying to make a solenoid with a core, and the formula my book gave me for the B field is B=μo*i*n where μo is the permeability of free space, i is the current in amps, and n is the number of coils. My book leads me to believe that B is in Teslas, but when I try out different numbers in Mathcad I get resulting units of Tesla-meters. I found on wikipedia B=[μo*i*n]/L where L is the length of the solenoid, and this gives me the units I'm looking for. Can someone point me into the right direction here?
Next question is, how do I relate the magnetic field of my electromagnet to the mass of the object I want to lift? I know I need to set the electromagnetic force equal to m*g*h, but I'm not sure where to go from there.
Am I even on the right track? If I'm not, I'd appreciate all the help I can get. I've searched and searched online trying to find this stuff but I haven't found anything overly helpful.
hey the n (for the B field is B=μo*i*n where μo is the permeability) you mentioned first time is no. of turns per unit length
the n you mentioned the second time is no. of turns N
n=N/L
L- length of the solenoid
As to the basic question , what you are trying to do is impossible because magnetic field of a solenoid OUTSIDE it is ZERO (practically negligible)
n=N/L
Thanks for the help with the first part. I'm embarrassed I didn't see that before.
As for the second part, if I add a ferromagnetic core (loosely quoting wikipedia), then the same equation holds true as long as I take into account the permeability of the core.
