Connection coefficients as derivatives of parallel propagator
ianhoolihan
Hi all,
I've been fiddling around with this problem for a while. I intuitively understand that the parallel propagator is the path integral of the connection. I would like to be able to show the converse (connection is derivative of parallel propagator) mathematically, and I am having a little trouble.
I've been thinking of the parallel propagator as in http://en.wikipedia.org/wiki/Parall...ng_the_connection_from_the_parallel_transport. I understand how to formulate the covariant derivative
<br /> \nabla_X V = \lim_{h\to 0}\frac{\Gamma(\gamma)_h^0V_{\gamma(h)} - V_{\gamma(0)}}{h} = \frac{d}{dt}\Gamma(\gamma)_t^0V_{\gamma(t)}\Big|_{t=0}.<br />
(Actually not really the second equality -- is this letting V_{\gamma(0)}=\Gamma(\gamma)_0^0V_{\gamma(0)}?)
However, the above link doesn't really show what the connection is. Yet, if you evaluate the last term of the above equation, then using the product rule you've got a term with the derivative of V and a term with the derivative of the parallel propagator. This is what you'd expect for the covariant derivative of a vector, where the connecton coefficients are the derivatives of the parallel propagator.
Nonetheless, I'm unable to make this all work out mathematically, so I was wondering if anyone could give me a hint? That is, on how the connection coefficients are the derivatives of the parallel propagator.
Cheers.
Well it looks like lots of people have viewed this thread, so I guess that means some interest. Can anyone shed some light, or offer a suggestion?
Cheers
Hello! There is a simple line in the textbook. If ##S## is a manifold, an injectively immersed submanifold ##M## of ##S## is embedded if and only if ##M## is locally closed in ##S##. Recall the definition. M is locally closed if for each point ##x\in M## there open ##U\subset S## such that ##M\cap U## is closed in ##U##. Embedding to injective immesion is simple. The opposite direction is hard. Suppose I have ##N## as source manifold and ##f:N\rightarrow S## is the injective...
