Why does velocity not vary with distance within 10 Mpc?
  • Thread starter Thread starter em370
    Velocity
The discussion centers on the unexpected behavior of velocity in relation to distance within 10 Mpc, where velocity does not increase as anticipated due to cosmic expansion. The concept of peculiar velocity is introduced, highlighting that nearby galaxies exhibit motion relative to the Milky Way, which complicates the interpretation of Hubble's law. The data suggests that there are significant deviations in velocity measurements, with some points showing anomalies up to 3-4% of the speed of light. Despite the reputable source of the data from Harvard's zcat, concerns are raised about the accuracy of the plotted velocities, particularly within the 10 Mpc range. Overall, the findings indicate that the relationship between velocity and distance is not straightforward, especially at closer scales.
em370
For a science project I used Harvard's zcat data to construct a graph in excel of the velocity and distance of distant objects. I expected velocity to increase with distance due to the expansion of space but it seemed to only begin once the object was 10 Mpc from Earth. I included the graph but it is very small due to file size restrictions.
Astronomy news on Phys.org
Well, all galaxies have a relative motion through space relative to the Milky Way. In the field this is called a peculiar velocity. In particular, it's meant to be distinguished from the speed inferred from cosmological expansion. For objects close to home, the peculiar velocity may be similar in magnitude to the speed inferred from Hubble's law. Only once we get to cosmological distance scales does this stop being true (since most galaxies move at most at speeds of several hundred km/s in clusters).
While the response from Steely Dan is true, the actual data looks really weird.
- at the linear part, velocity is not proportional to distance
- in our universe there is nothing magic at 10 Mpc, the region at 11Mpc is similar to the region at 9Mpc. However, the graph shows two regions which are completely different.
- compared to the small deviations of most of the data points, there are a few points which are really off, up to 3-4% c (as deviation to the line).
Both responses are good ones above. Just wanted to add that there seems to be lots wrong with your plot---the velocities are also way too large. Remember Hubble's law:
v \approx H_0 d \approx 70 \textrm{ km/s} \left( \frac{d}{1 \textrm{ Mpc} } \right)
I took all of the data from this website https://www.cfa.harvard.edu/~dfabricant/huchra/zcat/ so I can't vouch for how the testing was done but harvard is a reputable university. I did notice that the line was shifted upwards quite a bit but I thought whatever may be forcing objects within 10 Mpc to not vary with distance may also be responsible for that. Also, the section of data outside 10 Mpc gives hubbles constant as about 72 km/s per Mpc which is fairly accurate along with a high initial velocity at 0 Mpc, which according to posters is not accurate. The velocity measurements are recorded as observed at Earth based on redshift. I feel like I must be missing something because the data come straight from the zcat and I doubt a distinguished college would publish something if the velocity data was off by a large amount.
This thread is dedicated to the beauty and awesomeness of our Universe. If you feel like it, please share video clips and photos (or nice animations) of space and objects in space in this thread. Your posts, clips and photos may by all means include scientific information; that does not make it less beautiful to me (n.b. the posts must of course comply with the PF guidelines, i.e. regarding science, only mainstream science is allowed, fringe/pseudoscience is not allowed). n.b. I start this...
Asteroid, Data - 1.2% risk of an impact on December 22, 2032. The estimated diameter is 55 m and an impact would likely release an energy of 8 megatons of TNT equivalent, although these numbers have a large uncertainty - it could also be 1 or 100 megatons. Currently the object has level 3 on the Torino scale, the second-highest ever (after Apophis) and only the third object to exceed level 1. Most likely it will miss, and if it hits then most likely it'll hit an ocean and be harmless, but...
