Understanding 5G Beamforming Using Phased Arrays
  • Thread starter kevinisfrom
  • Tags
    Arrays
In summary: If you are looking for a narrow main lobe, a smaller antenna will give better results than a larger one. If you want a relatively wide main lobe with good coverage, a larger antenna will be better.
kevinisfrom
36
TL;DR Summary
My hypothetical question is, is it possible to suppress all side lobes (side lobes -->0) and create a beam with a very small angle (theta -->0) with antennas -->infinity? A more practical question, if the beam always spreads as it travels, does this mean the receiving antenna must be much larger than the transmitting antenna?
The general concept of 5G beamforming using phased arrays makes sense from the videos I've seen. Something I've noticed was that there are always side lobes and also the beam spreads as it travels. My hypothetical question is, is it possible to suppress all side lobes (side lobes -->0) and create a beam with a very small angle (theta -->0) with antennas -->infinity? A more practical question, if the beam always spreads as it travels, does this mean the receiving antenna must be much larger than the transmitting antenna?
No, the best you can do is what is called diffraction-limited. The larger your source the less diffraction you will have, but it will always be present.
No, it means that the transmitting antenna will transmit a lot of energy and the receiving antenna will receive very little energy.
Likes Tom.G
The simple rule of thumb is that the beamwidth of the main lobe will be 360°/ 2Pi = 57°, divided by the width (measured in wavelengths) of the antenna, or array of elements.
Likes Tom.G and Dale
Just re-read what you wrote. It would imply that every home TV aerial would need to be the same height as the cylinder at the top of the transmitting mast. How big is your antenna? Do you know of any localised radar systems that use different sizes for Tx and Rx? How could it be better to use a wider Tx beam than Rx beam? A shared antenna makes total sense in pretty much any radar system you would want to instal on a ship.
You could have made the time to read around about this topic and avoid asking some really flawed questions. The strength of received signal depends on every link in the comms chain. But a very small amount of reading around would have made all this sort of thing clear to you. There is no point in trying to reverse engineer in an attempt to learn about a subject.
On the subject of sidelobes. The rules of thumb formulae which give an idea of the width of an antenna beam are only approximate. Sidelobes can easily be suppressed by altering the weighting of the element feed powers. This will be slightly at the expense of the width of the main beam but it can fill in the nulls, too. Depending on what you actually want from the array, that can be an excellent solution for the available aperture. Weighting of array elements is dealt with in many textbooks and this link is an up to date paper which shows how sidelines can be dealt with, usefully.
Likes Dale
I think there is a subtlety here. The width of the main beam of an antenna is dependent on antenna size, but the side lobes lie outside this beam. By using a binomial distribution of energy across the antenna, sidelobes can be theoretically reduced to zero but at the expense of gain (ie broadening) of the main lobe. There are other distributions across the antenna which allow us to trade forward gain for sidelobe level.
Likes sophiecentaur and Dale
Indeed. In the case of a service like 5G (which is just the same as broadcast TV and other systems, the nulls can be a worse embarrassment than the sidelobes as the vertical radiation pattern in particular will need to have a main beam slightly tilted to the ground (a max that points just short of the wanted service area limit - sometimes the horizon) and all the nulls filled so 'everyone gets a bit' in the service area.
The 'best' antenna depends entirely on the requirement.
FAQ: Understanding 5G Beamforming Using Phased Arrays
1. What is 5G beamforming?
5G beamforming is a technique used in wireless communication networks to focus and direct radio waves towards a specific target, such as a user's device. This allows for more efficient and reliable communication, as well as increased network capacity.
2. How does beamforming work in 5G networks?
In 5G networks, beamforming works by using phased array antennas, which consist of multiple antenna elements that can be controlled individually. By adjusting the phase and amplitude of each antenna element, the radio waves can be steered towards a specific direction, creating a focused beam towards the target device.
3. What are the benefits of using phased arrays for beamforming in 5G?
Phased arrays offer several benefits for beamforming in 5G networks, including improved signal strength and coverage, reduced interference, and increased network capacity. They also allow for dynamic beamforming, meaning the direction of the beam can be adjusted in real-time to track the movement of the target device.
4. Are there any challenges or limitations to using phased arrays for 5G beamforming?
While phased arrays offer many advantages for 5G beamforming, there are also some challenges and limitations. These include the complexity of designing and implementing the arrays, as well as the potential for increased power consumption and cost.
5. How is 5G beamforming using phased arrays different from previous generations of wireless networks?
Previous generations of wireless networks, such as 4G, typically used omni-directional antennas, which transmit radio waves in all directions. 5G beamforming using phased arrays allows for more targeted and efficient communication, making it possible to support higher data rates and more devices on the network.
