What is the Solution for $5^x+2=12$?
  • MHB
  • Thread starter karush
I forgot to change it in the contentIn summary, the solution to the equation $5^x+ 2= 12$ is $x= \dfrac{\ln(10)}{\ln(5)}\approx \boxed{1.4307}$.
karush
MHB
3,269
Solve $5^x+2=12$
$5^x=10\implies x\ln(5)=\ln(10)\implies x=\dfrac{\ln(10)}{\ln(5)}\approx \boxed{1.4307}$
ok i think this is ok but typos or better steps maybe
Mathematics news on Phys.org
karush said:
Solve $5^x+2=12$
Looks good. The only possible improvement I might suggest is to use \(\displaystyle log_5\) instead of ln (then \(\displaystyle x = log_5(10)\)) but in practical terms most calculators don't have a key to evaluate \(\displaystyle log_5(10)\) so I'd use ln, too.
-Dan
You solved $5^x+ 2= 12$ but the title of this thread was "Solve $5^x+ 2= 126$". Which is it?
If the problem is actually $5^x+ 2= 126$ then $5^x= 124$, $log(5^x)= x log(5)= log(124)$ so $x= \frac{log(124)}{log(5)}$. Since $5^3= 125$ x will be a little less than 3. Using a calculator, x is about 2.99500933 .
sorry I edited the title to what I solved
What is the equation being solved?
The equation being solved is $5^x+2=12$.
What is the value of x?
The value of x is 1.4307.
What method was used to solve the equation?
The equation was solved using logarithms.
Can this equation be solved without using logarithms?
No, this equation cannot be solved without using logarithms.
What is the significance of the solution to the equation?
The solution to the equation represents the value of x that satisfies the equation and can be used to find the point where the graph of $5^x+2=12$ intersects with the x-axis.
  • General Math
  • General Math
  • General Math
  • General Math
  • General Math
  • General Math
