Calculate NaCl Density at 20C in lbs/ft3 | SG & PV=nRT Methods
  • Thread starter Thread starter zeshkani1985
    Density
To calculate the density of NaCl at 20°C in lbm/ft³, specific gravity can be used, which is approximately 2.1 times the reference density of solids/liquids (62 lbm/ft³). This results in a density of about 130.2 lbm/ft³ when converted. The discussion also mentions using the ideal gas law (PV=nRT) to find density, but this is not applicable for solids. It is noted that assuming a volume of 1 ft³ simplifies the calculation. Overall, using specific gravity is the most straightforward method for this density calculation.
zeshkani1985
Calculate the density of NaCl at 20C in lbm/ft3 ?
since no volume was given i was wondering if this can be done this way
by using the Specific gravity which around 2.1x the referance density of solids/liquids which is 62 lbm/ft3 SG=p x pref
or can this be done using the PV=nRT, i assume at 1 mole so V=RT since D=m/v
D=m/(RT)
D=58(g/mol)/(8.3x293K)=0.024
i was also thinking of calculating the density using the FCC cube and go from there, I just think i' am making this problem seem harder than it is
Any feed back is appreciated
thx
PV=NRT is for ideal gases, not for soilds.
If you are given specific gravity all you have to do is to convert from one units to another.
I just wanted to point out that you are given a volume... it says "in lbm/ft3". So you can assume a volume of 1 ft³.
Borek is the chemistry expert here though, so follow his approach! :)
