How Does Gibbs Free Energy Relate to Phase Changes?
During phase changes, such as melting, the temperature of a substance remains constant while energy is used for the phase transition, leading to a situation where Gibbs free energy (ΔG) is zero. This occurs because, at equilibrium between phases, the enthalpy (ΔH) and entropy (ΔS) increase, satisfying the relationship ΔG = ΔH - TΔS. The discussion clarifies that ΔG is not constant overall but equals zero during reversible phase changes, indicating equilibrium. Additionally, the sign of ΔG determines whether a process is spontaneous, with ΔG being greater than zero when temperature changes occur without a phase transition. Understanding these principles is crucial for analyzing phase changes and their thermodynamic implications.
AbsoluteZer0
Hi,
As I understand, during the process of phase change from a liquid to solid (or any phase change for that matter,) the temperature of the substance remains constant as the energy being applied to the substance is used in changing phase.
How does this relate to Gibbs free energy? I read that \Delta G during melting is zero. Enthalpy and entropy, however, increase. Does this have any relation to the uniformity of the temperature of the substance during the change of phase?
I'm led to believe that \Delta G > 0 when phase change isn't taking place because of the changing temperature. (For example, when the temperature of water is raised from 30°C to 50°C.) How accurate is this assumption?
Thanks,
AbsoluteZer0 said:
Hi,
Thanks,
Gibbs free energy is not constant during phase change! Who told you this ?
Clearly ΔG=ΔH-TΔS
Entropy factor also changes though...
During a reversible phase change, e.g. slow melting of ice, G does not change.
##dG=VdP-SdT+\mu_l dN_l +\mu_s dN_S.##
P and T are constant and ##dN_l=-dN_s##. ##\mu_l=\mu_s## is the condition for equilibrium of the two phases, so dG=0.
ΔH is positive for melting (endothemal process), ΔS, too, as the entropy of the liquid is higher than that of the solid.
AbsoluteZer0 said:
<snip>
<snip>
The sign of ΔG tells you if the process is spontaneous (ΔG < 0) or not. As for phase transitions, there are at least 2 kinds: a 'first order phase transition' is accompanied by a discontinuous change in the derivative of the free energy and are associated with freezing/melting/etc. ΔG = 0 for a first order phase transition (ΔH = TΔS).
Second-order phase transitions are associated with discontinuous changes to the second derivative of the free energy. IIRC, ΔG = 0 for a second order phase transition as well.
http://www.helsinki.fi/~serimaa/soft-luento/soft-2-phase.html
Thanks
Thread 'Gauss' law seems to imply instantaneous electric field propagation'
Imagine a charged sphere at the origin connected through an open switch to a vertical grounded wire. We wish to find an expression for the horizontal component of the electric field at a distance ##\mathbf{r}## from the sphere as it discharges. By using the Lorenz gauge condition: $$\nabla \cdot \mathbf{A} + \frac{1}{c^2}\frac{\partial \phi}{\partial t}=0\tag{1}$$ we find the following retarded solutions to the Maxwell equations If we assume that...
Maxwell’s equations imply the following wave equation for the electric field $$\nabla^2\mathbf{E}-\frac{1}{c^2}\frac{\partial^2\mathbf{E}}{\partial t^2} = \frac{1}{\varepsilon_0}\nabla\rho+\mu_0\frac{\partial\mathbf J}{\partial t}.\tag{1}$$ I wonder if eqn.##(1)## can be split into the following transverse part $$\nabla^2\mathbf{E}_T-\frac{1}{c^2}\frac{\partial^2\mathbf{E}_T}{\partial t^2} = \mu_0\frac{\partial\mathbf{J}_T}{\partial t}\tag{2}$$ and longitudinal part...
Thread 'Recovering Hamilton's Equations from Poisson brackets'
The issue : Let me start by copying and pasting the relevant passage from the text, thanks to modern day methods of computing. The trouble is, in equation (4.79), it completely ignores the partial derivative of ##q_i## with respect to time, i.e. it puts ##\partial q_i/\partial t=0##. But ##q_i## is a dynamical variable of ##t##, or ##q_i(t)##. In the derivation of Hamilton's equations from the Hamiltonian, viz. ##H = p_i \dot q_i-L##, nowhere did we assume that ##\partial q_i/\partial...
