Question about horsepower for car
  • Thread starter Thread starter scott22
    Car Horsepower
To determine the horsepower needed for a 3,500-pound diesel car with a 250HP motor going up a 2-3 degree incline at 20 mph, one must consider both the work done against gravity and additional losses like friction and air drag. The basic calculation shows that the car raises 2 feet per second, resulting in 420,000 foot-pounds of work per minute, which translates to about 12.73 horsepower, excluding inefficiencies. It's important to factor in wind resistance, which can be estimated using the drag equation, as the drag force increases with speed. The drag coefficient typically ranges from 0.25 to 0.30, depending on the vehicle's make and model. Overall, while the horsepower requirement for the incline alone is modest, additional factors like drag become significant at higher speeds.
scott22
I am wondering how much horsepower would be needed, or generated (not sure which term is right), if a diesel car with a 250HP motor, and weighs 3,500 pounds, is going up a slight incline (maybe 2 or 3 degrees) averaging 20 mph? Thanks.
The minimal power is given by the usual formulas for an inclined plane, but cars are quite inefficient and you have additional losses for friction, air drag, and other losses that are impossible to quantify with the parameters you gave.
Likes 1 person
A first cut would be to just estimate the work done raising the car as it goes up the incline.
20 mph is about 30 ft/sec and a 3 degree incline is about 1 foot in 15, so the car is raised 2 ft per second.
You will find that the horsepower equivalent is surprisingly modest.
Likes 1 person
Thanks for the info! Is it at all possible to get a ballpark number for horsepower based on the parameters I have given. If so, a thousand thanks!
In 60 seconds, your car is going up 2ft/sec x60sec =120 feet.
It weighs 3500 pounds, so the work done in one minute is 3500x120 foot pounds= 420,000 foot pounds/minute.
Google one horsepower, it is 33,000 foot pounds/minute, so...
Etudiant has given you most of it, you might also consider adding an estimate of wind resistance. The equation to calculate the net force would be:
Wikipedia: Drag Equation
You can estimate the car's drag coefficient to be somewhere between 0.25 - 0.30 but is dependent on make/model and you will also need frontal area. You can look up some typical make/model drag area values (product of C.d and A) here: Wikipedia: Automobile Drag Coefficient
Once you calculate the drag force, calculate power (Power = force * velocity); for 20 mi/hr this number may be small, but at 40 mi/hr and up it will increase dramatically (velocity squared term).
Likes 1 person
Thread 'I need a concave mirror with a focal length length of 150 feet'
I need to cut down a 3 year old dead tree from top down so tree causes no damage with small pieces falling. I need a mirror with a focal length of 150 ft. 12" diameter to 36" diameter will work good but I can't think of any easy way to build it. Nothing like this for sale on Ebay. I have a 30" Fresnel lens that I use to burn stumps it works great. Tree service wants $2000.
Hi all, i have some questions about the tesla turbine: is a tesla turbine more efficient than a steam engine or a stirling engine ? about the discs of the tesla turbine warping because of the high speed rotations; does running the engine on a lower speed solve that or will the discs warp anyway after time ? what is the difference in efficiency between the tesla turbine running at high speed and running it at a lower speed ( as fast as possible but low enough to not warp de discs) and: i...
20K
11K
