Is this matrix exponentiation method correct?
  • Thread starter Thread starter Jhenrique
    Matrix
The matrix exponentiation method presented contains multiple errors. The assumption that the exponential of a sum of matrices equals the product of their exponentials is incorrect unless the matrices commute. Additionally, the claim that scaling a matrix by a scalar can be expressed as the exponential of the matrix raised to that scalar is also flawed. The discussion highlights the need for a correct understanding of matrix exponentiation properties. Overall, the method proposed does not yield valid results due to these misconceptions.
Jhenrique
Is correct my step by step below?
<br /> \begin{aligned}<br /> \exp \left (\begin{bmatrix} a_{11} &amp; a_{12} \\ a_{21} &amp; a_{22} \\ \end{bmatrix} \right ) &amp;= \exp \left ( a_{11} \begin{bmatrix} 1 &amp; 0 \\ 0 &amp; 0 \\ \end{bmatrix} + a_{22} \begin{bmatrix} 0 &amp; 0 \\ 0 &amp; 1 \\ \end{bmatrix} + a_{12} \begin{bmatrix} 0 &amp; 1 \\ 0 &amp; 0 \\ \end{bmatrix} + a_{21} \begin{bmatrix} 0 &amp; 0 \\ 1 &amp; 0 \\ \end{bmatrix} \right ) \\<br /> &amp; = \exp\left ( \begin{bmatrix} 1 &amp; 0 \\ 0 &amp; 0 \\ \end{bmatrix} \right )^{a_{11}} \exp\left ( \begin{bmatrix} 0 &amp; 0 \\ 0 &amp; 1 \\ \end{bmatrix} \right )^{a_{22}} \exp\left ( \begin{bmatrix} 0 &amp; 1 \\ 0 &amp; 0 \\ \end{bmatrix} \right )^{a_{12}} \exp\left ( \begin{bmatrix} 0 &amp; 0 \\ 1 &amp; 0 \\ \end{bmatrix} \right )^{a_{21}} \\<br /> &amp;= \begin{bmatrix} 1 &amp; 1 \\ 1 &amp; 0 \end{bmatrix}^{a_{11}} \begin{bmatrix} 0 &amp; 1 \\ 1 &amp; 1 \end{bmatrix}^{a_{22}} \begin{bmatrix} 1 &amp; 1 \\ 0 &amp; 1 \end{bmatrix}^{a_{12}} \begin{bmatrix} 1 &amp; 0 \\ 1 &amp; 1 \end{bmatrix}^{a_{21}}<br /> \end{aligned}
Mathematics news on Phys.org
Hi Jhenrique! :smile:
Hint:
i] what is exp##\begin{bmatrix} a & 0 \\ 0 & a \\ \end{bmatrix}## ? what is exp##\begin{bmatrix} 0 & a \\ a & 0 \\ \end{bmatrix}## ?
ii] do your final matrices commute? :wink:
Jhenrique, I fixed your LaTeX so it doesn't spill across the screen.
The answer to your question is no. You made multiple errors. Your second line erroneously assumes ##\exp(A+B) = \exp(A)\exp(B)## and also erroneously assumes ##\exp(sA)=\exp(A)^s##.
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
