Question Regarding Capacitance And Inductance
To find capacitance using initial charge, inductance, and energy, the formula C = ½ Q² / E can be applied, where Q is the initial charge and E is the energy stored. The discussion highlights that knowing the initial charge and energy is sufficient to compute capacitance. The relationship between capacitance and voltage is also noted, with V = Q / C. The circuit in question consists solely of a capacitor and a solenoid. This approach provides a clear method for calculating capacitance in the given context.
bobbles22
Hi there,
I'm doing a home study course including a section on dynamic fields and waves. I am trying to understand how to find capacitance using initial charge, inductance and energy.
From a previous section, I know I can find the maximum current using Um=1/2 LI2
However, I can't see how to find the capacitance. Can anyone point me in the right direction please.
Many thanks
Bob
bobbles22 said:
Hi there,
Many thanks
Bob
What does the circuit look like? Can you upload a PDF?
Knowing the initial charge and energy should be enough to compute capacitance.
From the definition of capacitance, C = Q / V
therefore V = Q / C.
We know that the energy stored in a capacitor is, E = ½ C V^2
therefore E = ½ C (Q/C)^2
so E = ½ Q^2 / C
hence C = ½ Q^2 / E.
Its a simple circuit with just a capacitor and a solenoid, nothing else
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
