Improved Precision Rectifier Circuit Benefits
The improved precision rectifier circuit prevents the op-amp from saturating, requiring the output to change by two diode voltage drops (approximately 1.2 V) when the input crosses zero. This means that if the input is 5 V, the output does not simply reduce to 3.8 V; rather, it must account for the diode voltage drops. The circuit still needs to overcome the forward voltage of the diodes, ensuring one diode conducts while the other does not during the input transition. When the input fluctuates between +1 mV and -1 mV, the overall output changes minimally, around 1 mV, despite the op-amp output varying significantly. Understanding these dynamics is crucial for effective circuit design and application.
angelspikes
I'm having trouble understanding the following sentence, regarding an improved precision rectifier circuit:
This circuit has the benefit that the op-amp never goes into saturation, but its output must change by two diode voltage drops (about 1.2 V) each time the input signal crosses zero.
(1) What is meant by "change by"? If for example, the input is 5 volt, would the output change by 5 - 1.2 = 3.8 Volt?
(2) Is it still necessary in this circuit, to overcome the forward voltage?
http://en.wikipedia.org/wiki/Precision_rectifier
One of the diodes D1 and D2 is always conducting and the other one is not.
When the input goes through 0V, the other diode starts to conduct. The output of the op-amp has to flip between about +0.6V and -0.6V to provide the voltage drop across the correct diode.
If the input changes between say +1mV and -1mV, The output of the whole circuit only changes by about 1mV, even though the output of the op amp changes by about 1.2V.
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
Thread 'Beauty of old electrical and measuring things, etc.'
Even as a kid, I saw beauty in old devices. That made me want to understand how they worked. I had lots of old things that I keep and now reviving. Old things need to work to see the beauty. Here's what I've done so far. Two views of the gadgets shelves and my small work space: Here's a close up look at the meters, gauges and other measuring things: This is what I think of as surface-mount electrical components and wiring. The components are very old and shows how...
