Debunking the Myth: Can a String of Bucky Balls Stretch to Infinity?
  • Thread starter Thread starter KamakaziX
    Balls String
The discussion centers on the feasibility of creating a long string of bucky balls, specifically whether it can stretch to an extremely large number or an infinite length. One participant argues that the mass of the chain would eventually exceed the magnetic force holding the top ball, limiting the number of balls to around 950 based on calculations using their weight and pull force. The opposing view initially suggested the possibility of an infinite string but later acknowledged a finite number in the thousands. The debate highlights the importance of factors such as magnet strength and environmental conditions in determining the maximum length achievable. Ultimately, the consensus leans towards a finite limit based on physical laws and the properties of the magnets involved.
KamakaziX
We have had a heated debate at work and I feel we need to bring in a few outsiders into help clear things up.
A co-worker of mine believes that if you had a string of bucky balls (small spherical neodymium magnets) held by only the top ball in the chain and allowed to hang such that you could have a string of balls that you would be able to construct "an extremely large number, but not infinite" string of balls (originally he said infinite but then backed down from that statement). He has said that this number is possibly in the thousands or more.
I, however, believe that you would just need enough balls such that the mass of the chain below the first ball would overcome the force between the top two balls in the chain (plus the force from the top 5ish balls or so until the force from the subsequent ball's magnetic field, acting on the top ball, becomes negligible).
Who is more correct? I understand that a lot of this depends greatly on the power of the magnet, but assume that the magnets have a strength 2.1lbs of pull force. Sorry that I can't give you anything more specific I am having trouble determining the strength of the same magnetic balls that we have from manufacturer webpages.
Well, it all depends on the space you decide to put the buckyballs in, as that would determine the forces acting on them. Making a few really general assumptions, that we are starting at sea level on Earth and that each ball weighs 1 gram. Using F = ma, 2.1 lbs converts to about 9.34 Newtons, so we have 9.34 = m * 9.81. Solving for m gives us .950 kg, so you could string 950 buckyballs at the Earth's surface. From what I've read on the internet the balls have a 5mm diameter so that would be a 4.75 meter string. Rough estimate.
Hi there, im studying nanoscience at the university in Basel. Today I looked at the topic of intertial and non-inertial reference frames and the existence of fictitious forces. I understand that you call forces real in physics if they appear in interplay. Meaning that a force is real when there is the "actio" partner to the "reactio" partner. If this condition is not satisfied the force is not real. I also understand that if you specifically look at non-inertial reference frames you can...
I have recently been really interested in the derivation of Hamiltons Principle. On my research I found that with the term ##m \cdot \frac{d}{dt} (\frac{dr}{dt} \cdot \delta r) = 0## (1) one may derivate ##\delta \int (T - V) dt = 0## (2). The derivation itself I understood quiet good, but what I don't understand is where the equation (1) came from, because in my research it was just given and not derived from anywhere. Does anybody know where (1) comes from or why from it the...
