Calculating skewed distribution?
  • Thread starter Thread starter Aston08
    Distribution
The discussion focuses on calculating a skewed distribution of units sold between two price points while achieving a specific average price. The user initially outlines a method for even distribution but seeks guidance on how to adjust this to reach desired average prices of $30 or $20. Suggestions include selling fewer units at lower prices and more units at higher prices to balance the average. The conversation emphasizes the need to distribute sales as evenly as possible while still meeting the average target. Ultimately, the proposed method involves adjusting unit sales across the price range to achieve the desired average effectively.
Aston08
I am trying to calculate the distribution of a number of units between two points with a desired average not necessarily in the middle. In an even distribution I would normally find the difference between the two points and use the result to divide the number of units for distribution.
100 units
50 - 0 = 50
100 / 50 = 2 per interval
$50 / 2 = $25.00
So in the above if I had a 100 units that I wanted sell evenly for between $50 and $1 with an average price of $25. I would have to sell 2 units at $50, 2 for $49 ... and so on until inventory was depleted.
My question is let's say I wanted to sell the exact same number of units between the exact dollar values, but I wanted to skew my distribution so that my average final sale price was say $30 or $20. How would I go about calculating that ?
Mathematics news on Phys.org
100 units
50 - 0 = 50
$50 / 2 = $25.00
Actually, your average in this case would be $25.50 because you calculated 50-0 even though you don't include giving away 2 items for free.
\frac{2}{100}(1+2+...+50)
=\frac{1}{50}\sum_{i=1}^{50}
=\frac{1}{50}\cdot \frac{50(50+1)}{2}=\frac{51}{2}
I'm not exactly following what you want. You want to sell, say, 100 units and the prices you're restricted to is $1-$50 and you want to know what prices you should sell them at so that your average is close to some value $x? If so, what other restrictions are there, because you can do this in many ways. If not, could you please rephrase the question.
Yes, you pretty much have it covered.
My two main concerns are
1. Have a final average price of $x
2. Distribute the selling as evenly as possible between the starting and ending values.
So that say at $43 I know to sell x number of units and so on until the average is met and the inventory is completely liquidated.
Please feel free to ask any questions needed for clarity ...I don't do this type of math everyday so describing it doesn't come as second nature.
Ok I understand now. Like I said earlier, there are many ways to end up near the same average, but going by your "distribute evenly as possible" criterion, then here is one way I would suggest.
We already know that given 100 units sold over $1 - $50 evenly gives us 2 units per dollar sale, so if we want to be able to move units around, we should cut our starting point down to 1 unit per dollar sale (so we have 50 units left to work with) and we already know that the average for this is $25.50, so say you want an average of $30 then we need to start placing around the $35 mark.
The reason for $35 as opposed to $30 is because half of our values have an average of about $25, so when the other half then has an average of $35, the total average will be the average of $25 and $35 = $30.
So we first sell 1 of each unit at each dollar, then we sell as many units around $35 till we hit the $50 wall. So we would be selling $21 - $50 (a total of 30 units). Then we finally sell the last 20 units around $35 again, so we will be selling at $26 - $45.
In total, you will be selling
1 unit at 1-20
2 units at 21-25
3 units at 26-45
2 units at 46-50
The average is calculated by
\frac{1}{100}\left(\sum_{i=1}^{50}i +\sum_{j=21}^{50}j +\sum_{k=26}^{45}k\right) = 30.5
Notice however that the average is 30.5 for the same reason that you calculated 25.5 earlier (we really should have been placing around the $34.50 mark), if you want this fixed then just move 1 unit a total of $50 down, or 50 units by $1 each, or any variation thereof.
So if I shift the last 2 sums down by 1 value, we get the desired result:
\frac{1}{100}\left(\sum_{i=1}^{50}i +\sum_{j=20}^{49}j +\sum_{k=25}^{44}k\right) = 30
Suppose ,instead of the usual x,y coordinate system with an I basis vector along the x -axis and a corresponding j basis vector along the y-axis we instead have a different pair of basis vectors ,call them e and f along their respective axes. I have seen that this is an important subject in maths My question is what physical applications does such a model apply to? I am asking here because I have devoted quite a lot of time in the past to understanding convectors and the dual...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
