Convergence of a Recursive Sequence: Proving a_n*c*n\rightarrow 1 for Positive c
  • Thread starter Thread starter happyxiong531
    Sequence
The discussion centers on proving that for a recursive sequence defined by a_{n+1}=a_n(1-c*a_n/(1+a_n)), the product a_n*c*n converges to 1 for all positive constants c. The initial case where c=1 shows that a_n*n approaches 1, but challenges arise when c differs from 1. The user suggests that by redefining the sequence with b_n=ca_n, the convergence can be demonstrated, although they acknowledge their proof lacks rigor. Additionally, a condition is noted that ensures the positivity of the sequence elements, limiting the size of c. Overall, the user expresses confidence in their findings despite the need for a more formal proof.
happyxiong531
I want to prove that
if the sequence a_n satisfy that
a_{n+1}=a_n\left(1-c\frac{a_n}{1+a_n}\right)
then a_n*c*n\rightarrow 1 for all positive c.
Like when c=1, then a_n*n\rightarrow 1,
but if c\neq 1, it's difficult to prove.
Mathematics news on Phys.org
What makes you believe it is true? Your question implies a_n*n ->\frac{1}{c}. Doesn't look right, especially for large c.
mathman said:
What makes you believe it is true? Your question implies a_n*n -> 1/c. Doesn't look right, especially for large c.
Thank you for you reply.
I think it's correct.
First, I can have a_n*n\rightarrow 1 when c=1, from
a_{n+1}=\frac{a_n}{1+a_n}=\frac{a_{n-1}}{1+2a_{n-1}}=\cdots=\frac{a_1}{1+(n+1)a_1}
Then, let ca_n=b_n if c\neq 1, c is some constant. we can have b_{n+1}=b_n\left(1-\frac{b_n}{1+b_n/c}\right).
Actually, it's easy to prove a_n and b_n will go to zero,
so, \frac{b_n}{1+b_n/c}\sim\frac{b_n}{1+b_n}, thenb_n*n\rightarrow 1.
I have made a plot, it's correct no matter c is larger or less than 1.
But I think my proof is not strict.
Thanks for your concern.
Oh, I forget there is a condition that
the sequence should satisfy that1-c\frac{a_1}{1+a_1}>0,
so that all the elements in this sequence should be positive, and c cannot be too large.
I have made some plots like c=0.5, c=2, the conclusion is correct.
Thanks
Write out your complete proof.
Suppose ,instead of the usual x,y coordinate system with an I basis vector along the x -axis and a corresponding j basis vector along the y-axis we instead have a different pair of basis vectors ,call them e and f along their respective axes. I have seen that this is an important subject in maths My question is what physical applications does such a model apply to? I am asking here because I have devoted quite a lot of time in the past to understanding convectors and the dual...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
