9 large dimensions, No curled up ones?
  • Thread starter Thread starter KeithClemens
    Dimensions
KeithClemens
Any models worth checking out that do not rely on small curled up dimensions? And by large dimensions I don't mean 1mm, I mean all dimensions equally large.
Not that I know of. Even large (mm size) extra dimensions is kind of pushing it in the context of replacing one heirachy with another. You see, if the extra dimensions are large then we are immediately faced with phenomenological issues, i.e. where are they?
There are ways to 'hide' large extra dimensions. Sean Carroll came up with an interesting twist recently. http://arxiv.org/abs/0802.0521
The idea is to inject some generic field with a vev into the 5th dimension into a model.
In KK theory the momentum required to probe the extra dims is on the order of:
k\propto\frac{1}{r}
However, the existence of this lorentz violating field modifies the dispersion relations of say some scalar field and the momentum now reads:
k\propto\frac{(1+\alpha_\phi^2)}{r}
where \alpha_\phi is the ratio of the vev of the field to its coupling parameter.
Thread 'LQG Legend Writes Paper Claiming GR Explains Dark Matter Phenomena'
A new group of investigators are attempting something similar to Deur's work, which seeks to explain dark matter phenomena with general relativity corrections to Newtonian gravity is systems like galaxies. Deur's most similar publication to this one along these lines was: One thing that makes this new paper notable is that the corresponding author is Giorgio Immirzi, the person after whom the somewhat mysterious Immirzi parameter of Loop Quantum Gravity is named. I will be reviewing the...
I seem to notice a buildup of papers like this: Detecting single gravitons with quantum sensing. (OK, old one.) Toward graviton detection via photon-graviton quantum state conversion Is this akin to “we’re soon gonna put string theory to the test”, or are these legit? Mind, I’m not expecting anyone to read the papers and explain them to me, but if one of you educated people already have an opinion I’d like to hear it. If not please ignore me. EDIT: I strongly suspect it’s bunk but...
