A ball struck by a cue in billiards with English goes straight at first....
The discussion centers on the physics of billiards, specifically the behavior of a cue ball when struck with English (side spin) and how it differs from collisions between balls. Participants explore the mechanics of ball motion immediately after impact, the role of friction, and the implications of different cue designs.
  • Some participants suggest that the cue ball goes almost straight when struck on the side due to the nature of the force applied by the cue, which they argue propagates in the direction of the cue.
  • Others explain that the ball initially slips on the cloth and only begins to roll after colliding with another ball, indicating a transition from linear to rotational motion.
  • A participant questions whether the same slipping occurs when striking the ball softly above its center, seeking clarification on the mechanics involved.
  • Some argue that the cue ball does deflect slightly to the left when struck on the right side, but the primary direction remains aligned with the cue stick.
  • There is a discussion about the differences between ball-ball collisions and ball-cue collisions, with some noting that the cue's softer tip and longer contact time lead to different outcomes.
  • One participant raises the idea that using a low-deflection cue could result in less deflection of the cue ball, speculating that increased contact time and friction might contribute to this effect.
  • Another participant posits that if the cue ball were to stick to the cue during impact, it would travel straight with the cue, but questions whether it could turn towards the English during the collision.
Participants express a range of views on the mechanics of cue ball motion, with no clear consensus on the precise reasons for the observed behavior. The discussion includes competing explanations regarding the role of friction, the nature of collisions, and the effects of cue design.
Some claims about the effects of friction and the mechanics of collisions depend on specific conditions, such as the type of cue used and the force applied. There are unresolved questions about the implications of momentum conservation in different scenarios.
  • #121
And that is. . . ?
  • #122
sophiecentaur said:
And that is. . . ?
Look at the video.
  • #123
Is this a game in which you have to avoid giving an answer to my questions?
If you cannot say what the theory tells us then you cannot say whether or not the video (experiment) agrees with a theory. Does 'your' theory account for the ball motion being in the direction that the cue points, despite the acknowledged fact that the cue experiences a lateral force? Do you claim that contact with the table is not relevant? There would be a logical inconsistency if you do.
  • #124
I used the ball motion from the video. See post #112 & #114.
From what I have seen so far in this specific case, it seems not very relevant for the initial horizontal motion of the ball, right after the hit.
  • #125
A.T. said:
I used the ball motion from the video. See post #112 & #114.From what I have seen so far in this specific case, it seems not very relevant for the initial horizontal motion of the ball, right after the hit.
Have you observed that the motion appears to be in the line of the cue? Are you aware that there is a extra, lateral force involved (Described by players) which would produce a lateral motion. How are those two things reconciled if simple (2 D) theory tells us the ball travels in the direction of the force? There has to be another force involved. Can you think of a better mechanism than contact with the table?
  • #126
When? By what? On what?
  • #127
sophiecentaur said:
Something that you could help me with would be to explain when and why the "English" shot is choses, over a straight impact. Something to do with bending the path of the ball, I guess. Those professionals do some annoyingly clever stuff with how the ball behaves.
As an aside, as far as I know there are two distinct reasons to play with side (English). First is to swerve the cueball around an obstacle. The motion has two phases, first it goes fairly straight as it slips over the table, then it slows down and as it starts rolling, the side "takes" and the ball curves into the direction of the side. It's an easy way to get out of a snooker. The second common shot with side is to affect cueball position after it hits the object ball. The collision slows the cueball, the side takes from the collision onwards and the cueball rolls off into a direction different from the collision tangent.
I think your reasoning is sound. I only read 4 pages of this thread and skimmed over the rest (sorry) but it seems one factor has not been discussed in any detail, and that is that the cueball bounces off the table. It is nearly impossible to play a shot with a horizontal cue, so the friction contact between cue and cueball is pushing the cueball into the cloth. As the cue releases the cueball, the cueball bounces up off the cushion. Depending on the shot this is more or less pronounced, but in my experience (and backed up by your reasoning about the origin of lateral force) it always happens to some extent.
What I'm trying to say is, because of the downward angle of the cue, you are always pushing the ball into the cloth, so the spin axis of the ball is tilted forwards even on a vertically neutral (no top or back spin) shot.
  • #128
@AT. Read higher up the thread for comments on cue deflection and rigidity. In fact, try the whole thread for some background.
  • #129
Yes. It's definitely more complex than a simple 2D problem. Your comment on vertical cue angle is interesting. It would control slip and encourage the steering action. It's all very non linear so limiting friction is probably very relevant at all points of contact.
  • #130
As I have been saying throughout the thread. But for the specific case with the ball spinning around a close to vertical axis, a simple 2D approach seems to explain the result quite well.
  • #131
So a lateral force explains a motion with no apparent lateral component? Not much of an explanation, I would say.
  • #132
Maybe you can draw a diagram to explain better what you mean here. It's to vague.
  • #133
Only 'vague' because I presumed you had read all the comments about cue deflection. Lateral cue deflection is evidence of a lateral force. Irrespective of the stiffness, the force will exist. That force acts on the ball and will cause some lateral (leftwards, here) motion. Do you object to that?
You claim that the ball should follow the line of the cue. (Am I right in my understanding of what you have written?)
The lateral motion is not observed. So another force must be present. Ok?
Why do you claim that's not relevant on the basis of videos which do not measure forces?
  • #134
Where did I claim that? In the videos it's close but quite parallel.
  • #135
A video is just a video. Errors can't be avoided. What does "close" and "quite" mean? This is why I say theory is important; 2D theory is not enough for such a complex 3D situation.
You cannot tell what lateral forces are operating in the video so there is little useful information - except that the ball appears to go straight. You do not say how. I say it will need 3D analysis because the radial force is so significant. N
  • #136
Going back to an early video, note that the cue ball doesn't quite follow the path of the cue stick. The cue stick is angled slightly to the right in order for the ball to go straight in the video. It's best to watch the video in full screen to note the angle between the cue stick direction line and the ball direction line.
poolplayer said:
As noted many times by now, there are lateral component forces (Newton third law pair) between the cue tip and the cue ball, but since the cue stick flexes to the right, the cue tip has more of a reaction to the lateral component forces than the cue ball, so that the cue ball isn't deflected to the left much by the impact.
As for the reason behind putting pure side english on the cue ball, this is usually done to affect how the cue ball will react when it bounces off a cushion after striking a target ball (there's some interaction between the balls due to spin, but the biggest reaction occurs due to a bounce off a cushion). This is done to control where the cue ball ends up to setup the next shot. To curve a cue ball, a combination of back spin and side spin are used.
  • #137
But not parallel to the cue line. The ball goes left of the original cue line, while the cue goes right.
  • #138
Yes, I also made this point earlier in the thread. But how relevant is this effect really, during the short impact phase, if you strike as horizontal as possible, at mid height?
A quick estimate: With the queue at ~5° the downwards component is about 1/10 of the horizontal component. That adds to the table-normal force by gravity, which is negligible compared the the horizontal cue impact force. If the table-normal force is ~0.1 of the horizontal cue impact force, the table friction can be around 0.02 of it. So even if all that table friction acts to the right (which it most likely doesn't), you still have a very small effect compared to the cue impact force (~1deg change for the initial ball direction)
Later, over a longer time period, the friction due to spin can curve the path to the right, as described in the link I posted earlier.
  • #139
A complicating factor here is that a flexing cue will extend the contact time and a different amount of slip across the surface of the ball, which will (could) mean that there is more imparted spin round a vertical axis.
But N3 says that the two forces have the same magnitude. I am thinking that the radial Momentum imparted by the cue is not too much affected by this extended contact (it's more of an ideal collision because the mass of player + cue could be regarded as infinite) but the tangential Momentum could be affected much more with an extended contact because it can't be considered in the same simple way.
Is the cue ever horizontal? I watch a fair amount of Snooker on TV and the close up shots suggest there is nearly a significant downwards tilt when a hand bridge is used, True, the X rest is a bit lower than the hand but isn't the cue axis still higher than the centre of the ball? That downwards angle helps to strike with the flat end of the cue tip and will help to avoid unwanted slip against the table. The 1/10 factor you quote would be easily enough to control slip and a steeper attack would cause bounce and make control harder. Unsurprisingly, the angle has been chosen to work optimally.
Unfortunately, all these extra factors that we're bringing in only serve to show just how complex the system is that we're dealing with. A slippery disc is just not an adequate model and, in any case, it predicts a significant lateral motion. So we need to look for something else, to explain how this is eliminated by good players. And they may well be very unsuitable witnesses to what goes on because there is a massive amount of 'insulation' between their bodies' behaviour and what the ball does. Our brains just don't naturally do good Maths and Physics because they don't need to. Look at the way a Swallow or a Bat flies - dumb but amazing at the same time.
  • #140
sophiecentaur said:
The 1/10 factor you quote would be easily enough to control slip...
The 1/10 factor is for the table normal force. The max. table friction is just a fraction of that (~0.2). And the lateral friction component is some fraction of that. This limits the lateral table friction to ~0.02 of the horizontal cue impact force (in the specific case I was considering).
  • #141
That seems the wrong way round to me. The limiting friction force is less than the normal force but the normal component of the cue's force will increase the normal force (usually just the weight) considerably. 1/10 of the net, brief force from the cue will be greater (or at least as great) than the weight of the ball, which is easy to show from the fact that a struck ball can be lifted to a significant height above the table in some trick shots. So the net friction force, which is what will cause the ball to rotate, will be significantly higher with a slightly downwards stroke. It will be approximately proportional to the angle, aamof, because sin and tan are about the same as the angle for small angles (radians of course). Even if there is slippage, the tangential force against the table will still be greater than with a horizontal impact.
I have played very little pool but I have heard comments about 'controlling the ball' by digging in a bit, which justifies my view.
  • #142
sophiecentaur said:
So the net friction force, ..., will be significantly higher with a slightly downwards stroke.
Higher than from gravity alone. But still just ~2% of the horizontal force from a 5° downwards stroke. So at most ~1° horizontal direction change.
  • #143
How did you come to the 1 degree (could be correct, I don't see all the relevant math in my head)? 1 degree is enormous for a snooker player by the way. For a not-that-hard half table shot of ~1.7m a 1 degree deviation is more than the radius of a snooker ball, in other words the difference between a full ball contact and a miss.-
  • #144
If the friction is 0.02 of the impact force, then it can change the direction of the net force by max. atan(0.02) ~= 1°. But that assumes that it acts perpendicularly to the impact force, so it's actually even less than 1°.
Not for the question of the OP, which is to explain the ~15° deviation from the contact normal in his video.
  • #145
I am lost. I thought this was the discussion we were having:
- if there were no friction between cue tip and cueball and both were undeformable, the cueball would go 15 degrees left of the cue direction;
- there is friction in the contact, causing the force to be mostly imparted in the longitudinal direction of the cue, keyword mostly;
- the residual part causes the cue to flex away after the contact, and should cause the cueball to veer off to the left noticeably;
- pool and snooker players do not cue significantly out of line with their intended cueball path even when applying significant side however;
- therefore we are looking for any forces which explain the straighter-than-expected cueball trajectory.
You could even ask "is the majority of the cue deflection force converted into extra spin instead of cueball deflection?" and it would be the same analysis.
Did I misinterpret the problem? I thought we did away with most of the 15 degrees from the start assuming friction contact.
  • #146
If you agree that cue friction explains most of the ~15°, and table friction accounts for merely ~1° at best, then we have no disagreement.
  • #147
I thought the point of the top of this thread was that the ball goes more or less along the line of the cue and that needed explanation. No one would be surprised if it went as far as 15° off. The videos seem to show very nearly a parallel course and that's what I've been working to. No wonder you (A.T.) and I have been arguing the toss so much. :smile:
  • #148
It goes ~15° off the contact normal. That was what the OP asked about.
  • #149
In the video I am referring to (Post #24) the ball path is parallel with the cue. That was what the question needed an explanation for, as far as I can see. Have you seen it?
I am not sure how your 15° angle is relevant here when what counts is surely the direction relative to the line of the cue - which is how the player views the event.
  • #150
Exactly. I don't think the cue ball goes dead parallel with the cue, and I don't care 1° difference for now.
How can you be sure that? You really push the friction between the ball and table... The cue angle would be always downwards in the game because there are rails, but we always try to strike horizontally as possible. So, the angle should be less than 5° in most cases. In my videos, I would say shots are very horizontal because there is no rail on my table.
Anyway, I am going to post probably decisive evidence against the friction between the ball and table. I hang a ball with a rope in the air and stroke the ball with right English.
I am sorry for the low quality experiment, but you would agree that the ball still goes straight without contact with the table.
So, now we can focus on the real force that makes the ball goes rightwards from the normal direction.
  • · Replies 32 ·
