How Does a Hairdryer Use Less Current Despite High Home Voltage?
  • Thread starter Thread starter ethan12
    Electricity
In the UK, the electricity supply is 230 volts at 13 amps, but appliances like hairdryers use only the current they require, which is limited by their internal resistance. The fuse rating, such as a 3 amp fuse for a hairdryer, protects the appliance by preventing excessive current flow. This concept can be compared to a water faucet, where the pressure represents voltage and the flow rate represents current, regulated by the faucet's opening. Therefore, the full capacity of the circuit does not overwhelm the appliance because it only draws the necessary amperage. Understanding this principle clarifies how devices operate within the electrical system.
ethan12
Hi,
The UK., electricity supply is 13 amps at 230 volts. With such a current and e.m.f., how can we run appliances which don't need that e.g., a hairdryer with a 3 amp fuse. What stops the full 13 amps overwhelming the appliance? My question is not well put but I'm sure you know what I'm getting at. I'm a parent trying to help my son and I would like to give him the right answer even if the answer might take some thinking about. It's not for his homework just for our understanding.
Thank you for reading this.
Regards,
Ethan12.
Welcome to PF. The amp rating of a circuit is just a capacity. The electrical device draws whatever amperage it needs.
For a given amount of voltage, the current goes down as the resistance goes up, and the hair dryer has a certain amount of resistance in it.
You can think of similar situation with a water faucet. The pressure of the water is the voltage, and you can regulate the current by opening or closing the faucet.
I don't know much about electricity and I'm kind of talking out of my *** and/or oversimplifying it, so someone correct me if they can.
Thread 'Inducing EMF Through a Coil: Understanding Flux'
Thank you for reading my post. I can understand why a change in magnetic flux through a conducting surface would induce an emf, but how does this work when inducing an emf through a coil? How does the flux through the empty space between the wires have an effect on the electrons in the wire itself? In the image below is a coil with a magnetic field going through the space between the wires but not necessarily through the wires themselves. Thank you.
I was using the Smith chart to determine the input impedance of a transmission line that has a reflection from the load. One can do this if one knows the characteristic impedance Zo, the degree of mismatch of the load ZL and the length of the transmission line in wavelengths. However, my question is: Consider the input impedance of a wave which appears back at the source after reflection from the load and has traveled for some fraction of a wavelength. The impedance of this wave as it...
