Have you found a solution for the pain of bone marrow biopsies?
  • Thread starter Thread starter pmb_phy
Bone marrow biopsies are known for causing significant pain, prompting discussions on potential mechanical solutions to alleviate discomfort. One suggestion involves a specialized needle design developed by a biomedical engineer, featuring a rotating inner needle that minimizes pain but still causes discomfort. The conversation also touches on the idea of creating an access port in the bone to avoid repeated procedures, though concerns about bone overgrowth present challenges. While some mechanical solutions exist, they do not eliminate the pain entirely, indicating ongoing research and development is needed. Overall, the quest for improved methods to reduce pain during bone marrow biopsies remains a relevant topic in medical discussions.
pmb_phy
Are any of you familiar with a bone marrow biopsy? Is so then you're familiar with the enourmous amount of pain it causes.
Have any of you tried to solve this problems utilizing mechanics.
Pete
I will get back to you in about 10 years
I should have my Ph.D in Biophysics by then.
Jeremy
Well there is a simpel mechanical solution to this probleme it's derived from Newtons 3'rd law and it seas that no action couses no reaction. So if no bone marrow biopsy is preformed it couses no paine. Aldo this solutions does have a small problem, all the benefits of a bone marrow biopsy are lost. :smile:
My cousin was a biomedical engineer in New Jersey, and developed a more comfortable needle over 20 years ago. I don't know how widespread its use is, but it involved a rotating inner needle with a razor-sharp bevelled tip that bored into the bone like a hole-saw rather than punching through. Still hurt like hell, but it was an improvement. I wouldn't have much of a clue about how to approach something like this other than maybe Teflon-coating the parts or adding an electrical discharge to block local transmission of pain impulses.
Dang Pete, you going through that again? Will see what I can find.
Chronos' post leads me to suspect that this is an on-going experience for you. My sympathies. If you have to undergo it regularly, I'd think that it should be possible to install an access port in the bone itself that could be tapped into instead of having to make new holes every time. How to prevent the bone from over-growing it could be a nasty problem. I can't help thinking that there must be some insurmountable obstacles to it, though, or they'd already be doing it.
Thread 'Gauss' law seems to imply instantaneous electric field propagation'
Imagine a charged sphere at the origin connected through an open switch to a vertical grounded wire. We wish to find an expression for the horizontal component of the electric field at a distance ##\mathbf{r}## from the sphere as it discharges. By using the Lorenz gauge condition: $$\nabla \cdot \mathbf{A} + \frac{1}{c^2}\frac{\partial \phi}{\partial t}=0\tag{1}$$ we find the following retarded solutions to the Maxwell equations If we assume that...
Dear all, in an encounter of an infamous claim by Gerlich and Tscheuschner that the Greenhouse effect is inconsistent with the 2nd law of thermodynamics I came to a simple thought experiment which I wanted to share with you to check my understanding and brush up my knowledge. The thought experiment I tried to calculate through is as follows. I have a sphere (1) with radius ##r##, acting like a black body at a temperature of exactly ##T_1 = 500 K##. With Stefan-Boltzmann you can calculate...
Thread 'A scenario of non-uniform circular motion'
(All the needed diagrams are posted below) My friend came up with the following scenario. Imagine a fixed point and a perfectly rigid rod of a certain length extending radially outwards from this fixed point(it is attached to the fixed point). To the free end of the fixed rod, an object is present and it is capable of changing it's speed(by thruster say or any convenient method. And ignore any resistance). It starts with a certain speed but say it's speed continuously increases as it goes...
