A few basic induced current questions
The discussion focuses on confirming the understanding of induced current in a coil when influenced by a moving bar magnet. The coil's ends are correctly labeled as N and S, with the right-hand rule indicating a clockwise current flow. When the magnet stops moving, the induced current ceases due to a lack of changing magnetic flux, aligning with Faraday's Law of Induction. The responses provided demonstrate a solid grasp of the principles involved in electromagnetic induction. Overall, the participant shows a good understanding of the concepts related to their prelab work.
vsage
It's sunday night and I have another prelab to do. I wrote down all the answers I thought were correct but I'd like a little confirmation on these. See attached picture for the setup. The red lines indicate parts where the coil is looped away from the view and the black would be parts of the coil closer to view. Also, the arrow by the bar magnet means that the magnet is being moved in that direction.
2. In the diagram, label the ends of the coil N and S. Hint: like poles repel.
-I have N as the right side of the coil and S as the left
3. Now use the right-hand rule to determine what the direction of the current in the coil must be to produce the poles as determined in the previous step.
-I have clockwise through the system
4. Suppose the person gets tired and stops pushing the bar magnet, leaving it near the coil, motionless. How will this affect the coil current and why?
-The coil will lose current because there will no longer be a change in flux through any cross-sectional area.
It appears that you have correctly labeled the ends of the coil as N and S based on the direction of the arrow indicating the movement of the bar magnet. The right-hand rule is a useful tool for determining the direction of induced current, and it seems like you have used it correctly to determine a clockwise current flow through the system.
Your answer for question 4 is also correct. When the bar magnet is no longer moving, there is no change in flux through the coil, which means there is no longer an induced current. This is because a changing magnetic field is necessary to induce a current in a coil, according to Faraday's Law of Induction.
Overall, it seems like you have a good understanding of induced current and how it relates to the movement of a magnet near a coil. Keep up the good work on your prelab and good luck with your experiment!
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
