A few limit point compactness questions
  • Thread starter Thread starter radou
    Limit Point
radou
Let X be limit point compact (i.e. any infinite subset of X has a limit point).
(a) if f : X --> Y is continuous, does it follow that f(X) is limit point compact?
(b) if A is a closed subset of X, does it follow that A is limit point compact?
(c) if X is a subspace of the Hausdorff space Z, does it follow that X is closed in Z?
(a) well, if both X and Y are metrizable, this holds for sure, since limit point compactness of X implies compactness of X, which implies compactness of f(X), which then implies limit point compactness of f(X). otherwise, I don't see why this should hold.
(b) no, since for example [0, 1] is a closed subset of R in the lower limit topology, and it is not limit point compact
(c) well, again, if X is metrizable, X is compact, and hence closed in Z, since Z is Hausdorff. otherwise, I don't have an idea why it would hold.
any suggestions?
for a) take {0,1} with the indiscrete topology. Then
p_2:\{0,1\}\times\mathbb{Z}\rightarrow \mathbb{Z}
should do the job.
b) Correct. The example of above should do the job to.
c) Correct me if I'm wrong, but [0,\omega_1 [ is a non-closed countably compact (hence limit point compact) subset of the Hausdorff space [0,\omega_1].
should do the job.
micromass, thanks for the reply.
For c) does [0, ω1[ represent [0, ω1>? Which space are your referring to? i.e. what exactly does ω1 stand for, any real number?
\omega_1 is the first uncountable limit ordinal. I believe it is called \Omega in Munkres (this exercise is from Munkres, isn't it).
The space [0,\omega_1[ is the space S_{\Omega} of Munkres (although I'm not hundred percent sure of this).
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
