You could probably drive the correct waveforms from your uC into the power transistors that drive the motors -- might even get you extra credit in the project. You need to make the correct waveforms for the stepping and holding currents, but yeah, the uC could do that if you program it right.
A few questions about schematic
- Thread starter maverick99
- Start date
- Tags
- Schematic
46 replies · 14K views
- 10
If you did want to make a real world design as berkeman suggested, using a voltage regulator to step down a 9v supply to 5v is not hard. On the bench, you could determine how much current is drawn by your design and then decide if a 9v battery could work for the high supply..maverick99 said:Why would I have to include a power source and voltage regulators on the final project assembly? Wouldn't it work fine if I just used the 5 Volt line from my power supply and used the other output for 9V?
- 1,349
- 10
How will you mount the transducers so they will be turned by the stepper motor? Will transducers be on the same board as the rest of your circuit? I am trying to get a 3-dimensional idea of your final setup. Are you going to go with a circuit like the minibot one you posted at the http://www.leang.com/robotics/info/articles/minison/minison.html of this thread?maverick99 said:I plan on separating the two circuits. The stepper motor circuit will turn back and forth 180 degrees. Thats all it will do. I will have the transducers hooked up with long wires and mount them to something fairly sturdy to put on the motor to turn.
- 10
How about the range of your Ultrasonic Design. The spec for the project is 25feet. Only one of the circuits referenced on this thread are rated for that distance.
SRF04 Ultra Sonic Ranger
max range is 3m (x 3.28 ft/meter) = 9.84 ft
http://www.interq.or.jp/japan/se-inoue/e_pic6_6.htm
max range 3.6m (x 3.28 ft/meter) = 11.8ft
max range 5-6ft
http://www.ottawarobotics.org/articles/ultrasonic/ultrasonic.html
max range 10.7m (x 3.28) = 35 ft
If you did go with one of the other designs, is there a way to improve gain of the circuit?
Perhaps use more sensitive transducers?? (see below)
http://www.globalspec.com/FeaturedProducts/Detail/ScientificTechnologies/New_Ultrasonic_Sensors_for_Carwash_Applications/3542/0
Sensors with range 25ft
http://www.ssitechnologies.com/dislev6.htm
Sensors 8m (25ft)
max range 5-6ft
Sensors 8m (25ft)
maverick99
- 74
- 0
I will most likely use the circuit that has a max range of 5-6 feet basically because I already ordered the parts for it. I will be building it tommorow so I will test it out to see how far I can get it to go. On a side note, I got my stepper motor working from the 2 chips that I was given. The question I have is how to get it to stop at 180 deg, because it just keeps going 360 deg over and over. I noticed that there is a clockwise/counterclockwise pin on it but it does absolutely nothing when I put it to Vcc or ground. Any thoughts?
- 1,349
- 10
I'll just toss out some ideas as if I was in your design group and we were brain storming a bit.. I suspect you are using a microcontroller. How about programming it with a "lookup table" with each "binary input" equivalent to a "unit of angular displacement" (e.g. 1deg, 5deg.) Since you can count positive and negative numbers in binary, maybe you can use positive binary to translate 0 to +90deg and negative binary for -1 to -90 deg.
Berkeman had a suggestion of using limit switches at the ends of your 180 degrees of travel. I am guessing he means some sort of conductive pin to catch the rotor at the endpoints. With a conductive pin, it could trigger a switch (limit switch) to let your microcontroller know (closed circuit = voltage or logic level), that it has reached a boundary. If you used limit switches, all you would need is a counter to increment (step the motor), then when it reaches a limit switch, the counter could change to decrement, then when it reaches next switch, change to increment again, and so on..
I am wondering how you will mount your transducers & stepper motor (see my post #33 this thread). I am trying to get a 3-dimensional image of your setup..
maverick99
- 74
- 0
A couple days ago, I hooked up the stepper motor windings to a dip switch. After messing with it, I got it to turn clockwise by shifting to the left.
0001
0010
0100
1000...
...and counter-clockwise by shifting to the right.
1000
0100
0010
0001
Couldn't I make a program that would just shift so many times then shift counter-clockwise and put it on a microchip?
0001
0010
0100
1000...
1000
0100
0010
0001
- 1,349
- 10
Yes your program is a valid approach! Were you given a specification on how fast it should sweep from -90 to +90? Is your setup going to be stationary or mobile?
Whatever controls the motor, how will it know where a reference point is (example -90, 0, or 90 degrees)? For lab purposes, you could put it at a reference point. But wouldn't it be nice for your circuit to find the starting reference? That is another good reason to have at least one limit-switch.
maverick99
- 74
- 0
I hooked up the finalized circuit to the o-scope and I'm getting a good square wave from the transmitter circuit. Unfortunetly, my receiver circuit is still having problems. According to this site where I got the circuit from; http://www.leang.com/robotics/info/articles/minison/minison.html
It shows that I should have a square wave for my receiver circuit, but I'm getting a distorted sine wave. Any thoughts on what I should do?
Does it appear to be the return ping coming back? Like, does its time delay from the TX ping vary with the distance to the reflector? Does the amplitude of the distorted RX sine wave (before any final comparator stage) vary with reflector distance? I haven't looked at the circuit lately, but assuming there is an output comparator stage, are you saying that the output of the comparator is a distorted sine wave, or the input to the comparator?
maverick99
- 74
- 0
berkeman said:Does it appear to be the return ping coming back? Like, does its time delay from the TX ping vary with the distance to the reflector? Does the amplitude of the distorted RX sine wave (before any final comparator stage) vary with reflector distance? I haven't looked at the circuit lately, but assuming there is an output comparator stage, are you saying that the output of the comparator is a distorted sine wave, or the input to the comparator?
Edit: Ok the sine wave that I had was screwed up because of the 2nd line in the oscope. I plugged it into another and its working ok now. Here is a picture of what my oscope is showing now with my crappy camera phone.
http://img184.imageshack.us/img184/6643/picture0132kd.jpg
The top square wave is my pulse from the transmitter.
The bottom square wave is the pulse from the receiver.
I'm still having trouble with it though. When I put my hand in front of the sensors, the bottom pulse doesn't do anything until I'm maybe 6 inches away from it. When I do get close enough, it just shows the same waveform but flicking in different positions. The transmitter wave also gets affected a little too for some reason.
I didn't read the theory of operation at the leang website that you list, but IMO, you should be seeing something like this:
-- A 40kHz drive signal across the TX transducer for the duration of the 200us PING signal. A 40kHz signal has a 25us period, so you should get about 8 cycles of drive at 40kHz into the TX transducer for each PING. The 555 frequency should be tuned to the resonant frequency of the TX transducer. You can hand-tune the frequency in the next step...
-- Put an RX transducer directly in front of the TX transducer, and only connect your oscilloscope across the RX transducer (nothing else yet). Maybe separate them by 1mm or so. As the PING signal pulses, do you see a small signal on the RX transducer? I don't know how big the signal will be with only the oscilloscope input amp to magnify it, but I would think that you should be able to see it with such a small TX-RX separation. Worst case, you can touch the TX and RX transducer faces, but that will make the fine tuning of the TX frequency less valid. Assuming you see a small RX signal at 1mm spacing, fine tune the 555 frequency to maximize the amplitude of the RX signal. That fine tuning will help to maximize your sonar range.
-- Next, reconnect the RX transducer in your Receiver circuit, and watch the output of the first opamp stage. It should be an amplified version of the 8-cycle sine wave signal that you were seeing on your oscilloscope when you watched the output of the RX transducer alone. If it is not, then there is something wrong in the first stage amplifier circuit. If it is working right, then your gain will be set to barely get a good tone through the first stage when the reflecting object is at max range. With the gain set like that, the output of the first stage amp will be saturating into the rails when the reflecting object is very close. You might want to look into putting a soft saturation clamp circuit on the first stage to be sure that it doesn't slow down too much to keep up with return echoes from close objects. I'll leave that part as an exercise for the reader. Also, verify that the return echo of about 8 cycles at 40kHz (it may take a couple cycles for the RX transducer to ring up to full amplitude) get smaller in amplitude and more time-delayed as you increase the spacing between the TX and RX transducers (or increase the distance to the reflecting object). Remember that the speed of sound is about 340m/s at sea level, so expect about a 3ms delay for each meter of separation (ignoring circuit delays and ringup time factors, which you will need to calibrate out of your final answer).
-- Assuming the first stage is working okay, trace the signal through the 567 tone decoder. The 567 should provide some noise immunity against other noises that the RX transducer picks up. You should tune the 567 to be most sensitive to the frequency that you found from the earlier tuning that you did to maximize TX-->RX throughput. I've never used a 567, but it looks from the circuit like it will output a pulse when it sees a tone that is the same one it is looking for. I don't know how many of the 8 cycles it will take before the 567 drives its output, but you can probably figure that out from its datasheet.
Have fun!
Have fun!
maverick99
- 74
- 0
I got a question on finding the range using the oscope; tell me if this is the wrong approach in calculating the distance.
I measure how long the lag time is between the transmitter pulse and the echo. I multiply that by the period(50us). Then I multiply that by the speed of sound, which is around 300m/s. Would this work?
- 7,232
- 66
maverick99 said:I got a question on finding the range using the oscope; tell me if this is the wrong approach in calculating the distance.
The speed of sound in air is about 300m/s at 0C! In your much warmer lab the speed will be closer to 345m/s.
An RF radar transmitts a short pulse, then listens for a period of time fixed by the desired range. The amount of time between the transmitted pulse and the return gives the range. Keep in mind that the return time is 2 twice the time required for the pulse to reach the target.
The period of the pulse has nothing to do with the distance calc. the round trip time is just t=2*V/d. So d=2*V/t.maverick99 said:I got a question on finding the range using the oscope; tell me if this is the wrong approach in calculating the distance.
As Integral said, be more precise about V (and maybe include temperature and barometric pressure as inputs to your calculation, if appropriate). And you will need to calibrate out several other delay factors as well, if you want to increase your accuracy. You will need to measure what the RX delay through your input piezo and amp circuit is, since that will be an additional delay (which will likely change with distance, because it will change with gain and saturation effects in the input amp). There is also the ringup time of the TX piezo, potentially.
If you are using a microcontroller to operate the whole system, you can code up some calibration tables based on your oscilloscope measurements, and then fine tune them by working with test reflector objects. Remember, the 40kHz ultrasonic wavelet that you launch from your TX piezo will come back to your RX piezo as a much smaller 40kHz wavelet, and that's what you are picking up and amplifying. Part of the delay that you need to calibrate out is how the weaker the RX wavelet (farther distances), the farther into the wavelet your RX discriminator circuit will generally have to go before it trips to say that there is a valid echo.
maverick99
- 74
- 0
berkeman said:The period of the pulse has nothing to do with the distance calc. the round trip time is just t=2*V/d. So d=2*V/t.
Is V the velocity or voltage?
What do I use for t?
A few questions about RCD
- gen x
- · Replies 14 ·
- Electrical Engineering
- Replies
- 14
A few questions about capacitors
- Guidestone
- · Replies 17 ·
- Replies
- 17
A few questions about airflow and filters...
- SentinelAeon
- · Replies 5 ·
- Mechanical Engineering
- Replies
- 5
I have a few questions about refrigeration and AC units
- SentinelAeon
- · Replies 1 ·
- Replies
- 1
Undergrad A few questions about doing a Gaussian Fit
- btb4198
- · Replies 4 ·
- Linear and Abstract Algebra
- Replies
- 4
Undergrad Few Questions about: TU delft "A loophole-free Bell test"
- grzegorzsz830402
- · Replies 17 ·
- Quantum Physics
- Replies
- 17
A few questions about solid-state relays
- KingNothing
- · Replies 6 ·
- Replies
- 6
I have a few questions about Formalization & Pseudo-code
- CGandC
- · Replies 19 ·
- Math Proof Training and Practice
- Replies
- 19
High School I have a few questions about Warp drives? I am a layman.
- rgtr
- · Replies 4 ·
- Special and General Relativity
- Replies
- 4
High School A few questions about the covariant derivative
- etotheipi
- · Replies 7 ·
- Replies
- 7
