How Does a Man Accelerate While Climbing a Rope?
The discussion revolves around the mechanics of a man climbing a rope with acceleration, focusing on the forces involved, such as tension and friction, and the role of human physiology in this process. Participants explore the theoretical aspects of climbing, including free body diagrams and the nature of forces acting on the climber and the rope.
  • Some participants propose that the man pulls the rope, creating tension (T) and static friction that helps him climb.
  • Others question whether the friction involved is static or kinetic, suggesting it must be static since the man's hand is not in motion relative to the rope.
  • Some participants express confusion about the role of gravity (g) and how it fits into the climbing scenario.
  • A few participants emphasize the importance of static friction in preventing slipping, while questioning what force results in upward acceleration.
  • There are discussions about the forces acting on a small section of the rope and the climber's hand, including weight, static friction, and tension.
  • Some participants argue that tension should not be counted as a force acting on the hand, while others suggest that tension and friction can be equated in certain contexts.
  • One participant raises the idea that no work is done between the climber's hand and the rope, proposing that work is done between different parts of the climber's arm.
  • Another participant suggests that the original question lacks clarity regarding its context and scope, questioning whether it is a homework problem.
Participants express various viewpoints on the mechanics of climbing, with no consensus reached on the role of tension versus friction or the clarity of the original question. Multiple competing views remain regarding the forces involved and their interactions.
There is uncertainty regarding the definitions of forces involved, the assumptions made about the system, and the scope of the original question. Some participants note that the discussion could benefit from clearer context.
Kaushik
TL;DR
I am not able to understand what happens when a man climbs up a rope.
A man tries to climb up a rope with acceleration, ## a ##. What does he actually do to climb up?
My Interpretation
Let the man pull the rope at point A. So the Point A will pull the man with Tension, ## T ##. But at the same time the man is holding the rope, so there will be some normal reaction due to which there will be friction acting on the man in the upwards direction. So Is it ##T## and the Friction which pulls him up?
Is this friction static or kinetic? I first thought that it was kinetic, but at that instant the man's hand is pulling the rope but it is not in motion so static friction must act on it.
Is this the actual scenario? If not, what actually is happening? I am confused.
Thanks.
This question is a bit out of context. I'm guessing they are looking for a formula.
How does g (the acceleration due to gravity) fit into this?
I asked this to clarify my doubt. Like I can't get the intuition of what actually happens when a man tries to climb up.
For the hand to not slip on the rope, there must be a static friction force. It is complicated with a stranded rope because the is not cylindrical in shape.
It is irrelevant what the force of the hand pulling accomplishes.
So, static friction just prevents the hand from slipping. Then what is the force that makes the ##F_{net} > 0 ## i.e, in the upward direction? Is it Tension ?
It sounds like you are confused about the names of the forces.
A man climbing a rope is like a man doing chin ups on a horizontal bar. The forces in his shoulders, arms, elbows and wrists all contribute. Human physiology is very complicated.
Can you restate your question without a human body? Perhaps a weight hanging on a string.
Can we just discuss about what happens around our hand (The forces acting on it and by it)?
Draw up a free body diagram for a small section of rope where the hand grasps on. What forces can you identify that act on that section of rope?
I drew the FBD and noticed that the forces acting on that section of the rope are ## F ## with which the man pulls the rope down, ##T## from the supporting rope to keep the rope attached.
On man's hand, I noticed the following forces- ##Weight##, ## F_{static} ## to prevent the hand from slipping. I am not 100% sure but i feel like the rope also plays its role in preventing the man from falling by pulling it up with same ## T ##.
Yes. This is good. I had in mind two additional forces.
##T_{below}##: The tension in the section of rope below the man's hand
##-mg##: The weight of the small section of rope.
For an ideal massless rope, both additional forces are negligible.
You've already counted the force of the rope on the hand as ##F_{static}##. You do not get to count it again as tension.
jbriggs444 said:
You've already counted the force of the rope on the hand as FstaticFstaticF_{static}. You do not get to count it again as tension.
This is exactly where I am getting confused. Why don't we count Tension? How does the frictional force include the tension of the string?
Clearly, the real problem is deciphering what the question is trying to address. There is no indication of scope.
Is it sufficient to simply say that the climber is lifting with a force of ##<your formula>##? Is friction worth mentioning?
Tension acts within the string. It is the force between one section of the string and the next. In a more advanced context, one might not consider it to be a force at all, but something more like a condition (a component of the stress tensor).
Within the string you have tension. Outside the string you have friction. At the interface between the two you can equate the tension inside with the frictional force outside.
The free body diagram is what let's you equate friction and tension. If the chunk of rope where the climber hangs on has negligible mass and acceleration then the supporting force on that chunk (tension) must be equal to the external force that it encounters (friction).
Only the upward (static) friction force of the rope acts on the man's hand, not the rope tension. But, from a force balance on the section of rope spanned by the man's hand, the rope tension above the hand balances the downward friction force exerted by his hand on the rope. So the friction force is equal to the rope tension.
Could it be that no work is actually done between the climber’s hand and the rope? Is the real work being done between the climbers’s forearm which has effectively become “coupled” with the rope, and the climber’s upper arm, via the elbow? The upper arm “climbs” in relation to the forearm, which doesn’t climb? Part of the climber’s body climbs, another part stays stationary (until the climber grabs a different part of the rope with their other hand)?
Yes, all of the work is done by the muscles.
We're not supposed to post flat-out answers, but this thread is going in a very different direction than where I would have gone.
My answer to this question would have been:
The man applies a downward force of ##m_m(g+a)## to the rope.
Where:
##m_m## is the mass of the man;
##g## is acceleration due to gravity; and
##a## is the acceleration relative to the rope.
I would not have gone into the mechanics of climbing.
But what is the context and scope of the question? Who (or what) is the original author of the question. Is this a homework problem? If so, what lesson material is it associated with? What other question are on the homework paper?
.Scott said:
The man applies a force of mm(g+a)mm(g+a)m_m(g+a) to the rope.
I thought the climber applies the force to their forearm, (since the hand doesn’t move relative to the rope).
metastable said:
I thought he applies the force to his upper arm, (since the hand doesn’t move relative to the rope).
His upper arm is part of "he".
But it doesn't matter how he applies the downward force ##m_m(g+a)## to the rope. It will still result in climbing at acceleration of ##a##.
Perhaps there’s 2 climbing phases, one when the body is lifted, and one when the arm is lifted, and each phase has a different mass & acceleration term?
Or perhaps not. There is nothing that prevents the man from causing his center of mass to accelerate smoothly upward at the given rate. You are free to assume that the problem statement is correct.
But part of his body doesn’t accelerate at all during one phase (the hand).
But that does not prevent the center of mass from accelerating smoothly upward at all times.
Before you start your analysis, you first decide how to cut the system into bodies, and then stick to it. And yes, you can treat the hand and the rest of the person as separate bodies, just stay consistent about that.
If the climber is a small child with a very heavy hand or has a multiple kg wristwatch and we estimate the acceleration from the total body mass before the climb and force supplied, we could estimate an answer which is too low?
The hands are attached to the body. Their average velocity matches the average velocity of the body.
Why are you working so hard to make this problem harder than it is?
If we only look at the acceleration while the heavy hand grasps the rope, the hand won't accelerate, and no work is done on the hand, only to the rest of the body?
While one hand is holding on, unmoving, the other hand is moving upward at double speed to get to the next grab point. It balances out.
Can we make the hand that's holding the rope as heavy as we want, without affecting the acceleration of the rest of the body with a given force (assuming only the hand that's holding the rope is heavy)?
How can you climb hand over hand if you never move your hand?
  • · Replies 19 ·
  • · Replies 16 ·
