A number raise to it self infinitely
  • Thread starter Thread starter bigjoe5263
    Self
The discussion centers on solving the equation where a number x is raised to itself infinitely, expressed as x^(x^(x^...)) = 3. Participants emphasize the need to clarify the expression's meaning and the importance of defining the sequence properly. It is noted that while the sequence can converge, it does not necessarily converge to the expected value of 3, particularly for values of x greater than e. The conversation highlights that no value of x exists such that the infinite power tower converges to 3, and it delves into the implications of convergence based on the properties of logarithms and tetration. Ultimately, the conclusion is that while convergence can occur, it does not lead to the expected outcome in this specific case.
bigjoe5263
hi I have encountered this...
Code:
                                   X
                                X
                              X
                           X    =   3
I tried to solve it using properties of logarithims however I always end up with the initial equation... how will I find the value of X? ( x is raised to it self endlessly ).
:confused:
You have to parenthesize that exponential tower or it's ambiguous in meaning. 3^(3^3) is not equal to (3^3)^3. And as it's infinite, you need to express the meaning in terms of an infinite sequence. So start with a_0=x. Is a_n=x^(a_(n-1)) or is a_n=(a_(n-1))^x?
The generally understood meaning of the left hand side of that equation is the infinite power tower function
f(x) = x^{(x^{(x^{(x^...
or simply, work "downwards" from "infinity".
The "trick" solution to f(x) = N is to see that this implies x^f(x) = N hence x^N = N when a solution exists, giving x = N^(1/N).
The problem is that there is an upper bound on N for a solution to exist. I'll leave it to the OP to find that bound and hence deduce that f(x) = 3 has no solution.
If x^{(x^{(x^{(x^...}}} = 3, Then
x3= x^[{(x^{(x^{(x^...]}}}}= x^{(x^{(x^{(x^...}}}. What is that equal to?
Curios3141, I don't see why that "has no solution". Am I missing something?
Halls, try calculating f(x)=x^{x^{x^\cdots}} when x=3^{1/3}. It does not converge to 3. It does not converge, period. The upper bound on N is between 2 and 3 and is a very ubiquitous number.
How are you calculating that? If, for example, you calculate 31/3, store it in "x" in a calculator, do x^x, then "ans"^x, repeatedly, it does not converge.
But that is NOT f(x)=x^{x^{x^\cdots}}! To calculate that you need to repeatedly do x^"ans" and that does converge, slowly, to 3.
I misspoke. It does converge, just not to the value you expect. Let
f_1(x) = x
f_k(x) = x^{f_{k-1}(x)}
The desired function f(x) is
f(x) = x^{x^{x^{\cdots^x}} = \lim_{k\to\infty}f_k(x)
Now further define
g(x) = x^{1/x}
THe question at hand is f(g(x))=x? For x \in [ 1/e,e ], f(g(x))=x. The convergence is very slow as x approaches 1/e or e.
Things get a bit interesting when x>e. For example, f(g(3)) = 2.478053\cdots rather than 3. What's going on here? Note that g(3) = 1.44225\cdots. However, g(2.478053\cdots) = 1.44225\cdots also. The inverse of g(x) has two branches, with a branch point at e^{1/e}. f(g(x)) converges to g^{-1}(g(x)), where g^{-1} refers to the lower branch.
Things get even more interesting when x<1/e. The sequence \{f_k(x)\} doesn't converge. Instead, the sequence toggles between a pair of values as k\to\infty, one close to zero and the other close to one.
I'm a bit confused as to what converges, "converge, just not to the value you expect". The original problem was to solve
[tex\ x^{x^x^{\cdot\cdot\cdot}}= 3[/tex].
IF the sequence a_1= x^x, a_2= x^{a_1}, ... converges to 3, then x must be equal to 3<sup>1/3</sup>.
<br /> <br /> That&#039;s true. But the converse (if x=3^(1/3) then the sequence converges to 3) isn&#039;t true. The sequence does converge to a limit L that you can find by solving log(L)/L=log(3)/3 (not the L=3 root, the other root L=2.47805...).
I am going to have to meditate upon this!
HallsofIvy said:
IF the sequence a_1= x^x, a_2= x^{a_1}, ... converges to 3, then x must be equal to 31/3.
The problem is that no x exists such that the sequence \{a_k(x)\} converges to 3.
Halls, it's simple. The radius of convergence of the hyperpower function f(x) = ^{\infty}x (using the tetration notation) is ({(1/e)}^e, e^{(1/e)})
For x > e^(1/e), the function does not coverge.
For a value like 3^(1/3), the function *does* converge. But it does not converge to 3.
The function g(x) = x^{(\frac{1}{x})} reaches a maximum at x = e. In other words, you cannot find a value of x that makes g(x) > e^(1/e), so g(f(x)) will always converge for any real positive x > e.
So for N > e, f([N^(1/N)]) will never equal N, even though convergence will hold. Hence f(x) = N has no solution for x > e.
Hope that clarifies things. I haven't explored the lower bound this carefully, so I shan't comment on it.
Yes, thanks. I showed that "if the sequence of powers converges to 3, then x= 31/3. The converse, "if x= 31/3, then the sequence converges to 3" is not true.
Of course, the first condition (convergence to 3) will never actually be met.
D_H's f(g(x)) appears to provide solutions for x^y = y^x, x<>y, x>e.
For instance y=f(g(3)) is the other solution for 3^y = y^3, besides the obvious y=3.
When x=e, the only solution is y=e.
However, such solutions also exist when 1 < x < e, eg 2^4 = 4^2, but f(g(x)) does not help then, eg f(g(2)) = 2.
