A particle P is projected from a point O with velocity
A particle P is projected from point O with a velocity of 12i + 16j, and after two seconds, another particle Q is projected from the same point, colliding with P one second later. The collision occurs three seconds after P's projection, allowing for the calculation of P's position at that time. The key to solving the problem lies in determining the horizontal and vertical distances traveled by both particles to find the initial velocity of Q. The discussion emphasizes the importance of accurately interpreting the timing of the projections and the collision. Understanding these time intervals is crucial for solving the problem effectively.
VICKZZA
A particle P is projected from a point O with velocity 12i +16j .two seconds later,another particle Q is projected from O and collides with P after another second.Find the initial velocity of Q.
x=(vcosθ)(t)
y=vtsinθ-1/2gt^2
i think that Q will approach P when ts vertical and horizontal distance become equal with P.but i can't handle the time change or its accurates valuess...pleasezz help me out.....
How many seconds does the first particle spend in flight before the collision? What is the x,y location of the collision?
its not given in the question
Sure it is. Reread the question statement carefully.
its not there
VICKZZA said:
its not there
Yes, it is.
P is projected. 2 seconds later, Q is projected. Another second later, they collide.
Collision happens, 2 + 1 = 3 seconds after P is projected. From there, you should be able to easily work out the location of collision (where is P 3 seconds after projection?).
  • · Replies 17 ·
  • · Replies 35 ·
  • · Replies 31 ·
