A perfect square inside a circle and a perfect square
  • Thread starter Thread starter gonnis
    Circle Square
The discussion centers on the relationship between a perfect square inscribed in a circle and a perfect square circumscribing the same circle. Participants debate whether the areas between the inner square and the circle are equal to those between the circle and the outer square. To explore this, one user suggests starting with a unit circle and calculating the areas of the shapes involved. The conversation also touches on the terminology, noting that "perfect square" is redundant. Overall, the inquiry seeks to clarify a geometric concept involving areas and shapes.
gonnis
A perfect square inside a circle (so the inner square's corners touch the circle) and a perfect square surrounds the circle (so the circle touches the sides of the outer square. Are the extra bits between the inner square and the circle equal to the extra bits between the circle and the outer square?
Im not explaining this very good but hopefully the question makes sense. Don't know how to include a drawing here.
Thanks
Mathematics news on Phys.org
This looks like a homework question, if so it belongs in another forum I think.
Anyway, do you know the area of a square?
Do you know the area of a circle?
No barefeet this isn't a homework problem lol... its just been a while since I've thought about circles... I am asking in the context of before pi. OK its grade school question, its sort of stupid, but its legit, please indulge if you don't mind.
(fyi I asked a similarly dull question in gen discussion and they moved it to gen math, so I figured I may as well just post here because it would probably get moved lol)
thanks!
gonnis, why would you think the area between the inner square and the circle would be equal to the area between the circle and the outer square? Have you made an attempt to come up with an answer for yourself?
1. Start with a unit circle centered at the origin. Its equation is x2 + y2 = 1.
2. Inscribe a square inside the circle, then find the coordinates of the corners of the inner square.
3.Circumscribe a larger square around the circle, and find its corner points.
4. From the information obtained, you should be able to find the areas of all of the objects here, and thereby answer your question.
(BTW, "perfect square" is redundant - a square is a square.)
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
