A perfectly inelastic collision?
The discussion revolves around a physics problem involving a bullet and a block connected to a spring, focusing on the nature of the collision. The bullet passes through the block, leading to confusion about whether it's a perfectly inelastic collision. Participants clarify that energy is not conserved in this scenario, as the bullet's energy is transferred to the block and spring system. The correct approach involves using the spring's compression to determine the block's kinetic energy after the bullet exits and applying conservation of momentum to find the bullet's exit speed. The conversation highlights the importance of understanding energy transfer in collisions and the nuances of mechanical energy conservation.
00PS
A 5.00 g bullet moving with an initial speed of 410 m/s is fired into and passes through a 1.00 kg block. The block, initially at rest on a frictionless, horizontal surface, is connected to a spring of force constant 965 N/m.
1. If the block moves 5.20 cm to the right after impact, find the speed at which the bullet emerges from the block.
wrong check mark
p=mv (momentum)
(1/2)mv^2 (kinetic energy)
(1/2kx^2 (elastic potential energy of a spring, where x is the distance the spring is compressed)
-Energy is always conserved in a isolated system
-Momentum is always conserved in a closed isolated system
I am having a hard time grappeling what type of problem this is. A perfectly inelastic collision? But the bullet then exits the block...so a little tricky. Here is my attempt:
(1/2)mv^2(initial)=(1/2)mv^2 (final) - (1/2)kx^2
solving for v (final) i got 28.4 m/s
you are on the right track; this can definitely be solved with Energy considerations. First, you should check the sign on your 'spring energy' expression. What you are implying with that statement is that as the bullet compresses the spring, your bullet obtains more energy, when it is the opposite.
Welcome to PF!
wrong check mark
p=mv (momentum)
Hi 00PS! Welcome to PF! :smile:
No, energy is not always conserved in a isolated system … in fact energy is never conserved unless the question tells you it is! :smile:
There is no way that a bullet tearing a hole in something conserves energy! :rolleyes:
In this case, you have to work backwards …
you know how far the spring compresses, so you know what energy it got.
That energy came from the block, not the bullet, so you can work out the KE of the block after the bullet left it.
Then use conservation of momentum to find the speed of the bullet. :smile:
oops...already making use of my user name. :smile:
I simply forgot the word 'mechanichal'. According to my textbook, mechanical energy of a isolated system is conserved. Nonetheless, I asked my professor about the problem this morning in class, and he explained it exactly as you did, thanks! I knew conservation of momentum was involved somehow, but could not put my finger on how to apply it.
btw, thanks for the welcome! I found this site sort of as a joke using google, and to my surpise a phyics homework help does exist!
EDIT: Do you know how you could find how much mechanichal energy was transferred to internal energy?
