A problem about equivalent metric
  • Context: Graduate
  • Thread starter Thread starter prophetlmn
    Equivalent Metric
The discussion revolves around the properties of two metrics, d1 and d∞, defined on the space of sequences, particularly focusing on their equivalence and the convergence behavior of sequences under these metrics. Participants explore whether it is possible to prove the existence of a sequence that converges under one metric but not the other without relying on specific counterexamples.
  • One participant presents a counterexample involving sequences that converge under d1 but not under d∞, questioning if this can be proven without such examples.
  • Another participant suggests that to prove the claim, one must find sequences where d1 converges to zero while d∞ does not, indicating this is essentially what has been demonstrated.
  • A participant notes that the terminology used for the metrics d1 and d∞ is not standard, implying that they are typically defined differently.
  • There is mention of a friend's assertion that the conditions for equivalence of metrics are necessary in compact spaces but not in general, leading to a search for a counterexample in non-compact cases.
Participants express differing views on the necessity of conditions for metric equivalence and the validity of the presented counterexample. There is no consensus on whether the conditions discussed are necessary in general or only in specific cases.
Participants acknowledge the complexity of proving metric equivalence and convergence properties, with some noting limitations in their own proofs and the need for further exploration of non-compact cases.
prophetlmn
Given X=R∞ and its element be squences
let d1(x,y)=sup|xi-yi|
let d∞(x,y)=Ʃ|xi-yi|
then there exists some some x(k) which convergences to x by d1
but not by d∞ ,for example let x be the constant squence 0,
i.e xn=0 ,and let
x(k)n=(1/k2)/(1+1/k2)n
then d1(x(k),x)=1/k2
and d∞(x(k),x)=1+1/k2 by the use of geometry seire,
so as k goes to ∞, Lim d1(x(k),x)=0
Lim d∞(x(k),x)=1
my problem is that--- is it possible prove this without such counter example but merely prove the existence of such xk by general consideration on topology?
i.e if two metric are equivalent ,then they induce same topology,and same convergence properties. As a special case if there exist positive A B,such that for all x,y
Ada(x,y)≤db(x,y)≤Bda(x,y) then these two metric da and db are equivalent,it's obvious here d1(x,y)≤d∞(x,y),then we could have A=1 here,but for any positive M, there exist x,y such that
Md1(x,y)≤d∞(x,y) so no B exist
does this considerations led to the existence of x(k) in the counter example?
or Is Ada(x,y)≤db(x,y)≤Bdb(x,y) a necessary condition for da and db to be equivalent?
the original problem is from Tao‘s Real Analysis chapter12 Metric space ,the counter example is from Rudin’s Principles of mathematical analysis example 7.3 where he use a slightly different form and use it to show the limit of a squence of continuous function is not continous
To prove that this is true you have to find a sequence of x's and y's with d1(x,y) converging to zero, and d∞(x,y) not converging to zero. Which is essentially what you've done anyway
This is not the standard terminology. Usually, we swap these two metrics!
yes,but i mean another kind of proof,as i know from one of my friend if the metrics are compact then the condtion for A and B is necessary,while in general it‘s not,I have nearly got a proof about this yesterday,but tonight I found there is a small mistake in my proof,and l still have not got a counter example in the non compact case yet
  • · Replies 0 ·
  • · Replies 17 ·
  • · Replies 17 ·
