Proof by Induction: 3^n >= 1+2^n
Good luck!In summary, to prove that for all n in the natural numbers, 3^n is greater than or equal to 1+2^n, we can use induction. Starting with the base case n=1, we see that 3^1 is indeed greater than or equal to 1+2^1. Then, assuming that for some n, 3^n is greater than or equal to 1+2^n, we can show that 3^(n+1) is also greater than or equal to 1+2^(n+1) by using the inductive hypothesis and the fact that 3>2>1. Thus, we have proven that the statement holds for all values of
eku_girl83
89
Prove that for all n in the natural numbers 3^n greater than or equal to 1+2^n.
Here's my start:
3^1 greater than or equal to 1+2^1, so the statement is true for n=1.
Assume that for some n, 3^n greater than or equal to 1+2^n
Then 3^n+3^n+3^n greater than or equal to 1+2^n +3^n+3^n.
It follows that 3^(n+1) greater than or equal to 1+2^n+2*3^n.
Where do I go from here? I still need to show that 1+2^n+2*3^n is greater than or equal to 1+2^(n+1)
Thanks!
To show 3n+1>1+2n+1
subtract the n expressions from both sides, and you will have to show
2*3n>2n
That looks obviously true,since 3>2.
good work mathman!
So you'd like to prove that
[tex]3^n\geq 1+2^n[/tex]
using induction. The statement is obviously true for n=1, so all you have to do is to prove that if it's true for n=k, it's also true for n=k+1 (whatever k is).
So you should start like this:
[tex]3^{k+1}=3\cdot 3^k\geq 3(1+2^k)\geq\dots[/tex]
Now all you have to do is to show that this is
[tex]\geq 1+2^{k+1}[/tex]
This is very easy. (Hint: 3>2>1).
1. What is the concept of proof by induction?
Proof by induction is a mathematical technique used to prove that a statement is true for all natural numbers (1, 2, 3, etc.). It involves two steps: the base case, where we prove the statement is true for the first natural number, and the inductive step, where we assume the statement is true for a certain natural number and use that to prove it is also true for the next natural number.
2. How does proof by induction relate to the statement 3^n >= 1+2^n?
Proof by induction can be used to prove that the statement 3^n >= 1+2^n is true for all natural numbers n. This is because the statement can be broken down into two parts: the base case, where n=1 and 3^1 = 1+2^1, and the inductive step, where we assume the statement is true for n and use that to prove it is also true for n+1.
3. Why is it important to use proof by induction?
Proof by induction is an important tool in mathematics because it allows us to prove statements that are true for an infinite number of cases. It also helps us to break down complex problems into smaller, more manageable parts.
4. Can proof by induction be used for all mathematical statements?
No, proof by induction can only be used for statements that involve natural numbers. It cannot be used for statements that involve real numbers or other types of mathematical objects.
5. What are the potential pitfalls of using proof by induction?
One potential pitfall of proof by induction is assuming that the statement is true for all natural numbers without properly proving it. It is important to carefully follow the two steps of proof by induction and make sure that the statement is actually true for all natural numbers.
