A Question About Induction: Faraday's Law versus Motional EMF
  • Thread starter Thread starter MS La Moreaux
    Induction
The discussion revolves around the relationship between Faraday's Law and motional electromotive force (emf) in the context of a rectangular wire circuit that can change its area while moving in a static magnetic field. Participants explore the implications of both principles on the induced emf and the potential contradictions that arise from their application.
  • Some participants assert that the motional emf arises from the wire's motion through the magnetic field, while Faraday's Law accounts for the changing magnetic flux, suggesting both contribute to the total emf.
  • Others argue that the two principles are not independent and question the validity of applying both simultaneously, suggesting that one of the explanations must be incorrect.
  • A participant emphasizes that the mathematical formulations for both principles yield identical results, but the interpretation of these results may lead to confusion.
  • Concerns are raised about the physical interpretation of the principles, with some participants suggesting that mathematical equivalence does not imply physical equivalence.
  • There is a call for mathematical analysis to clarify the situation, with requests for diagrams and proper use of LaTeX for clarity.
  • Some participants express frustration over the inability to effectively use LaTeX for mathematical expressions in the discussion.
Participants do not reach a consensus on whether Faraday's Law and motional emf can coexist without contradiction. Multiple competing views remain regarding the interpretation and application of these principles.
Participants highlight the need for clear definitions and assumptions in their discussions, as well as the potential for misunderstanding due to the complexity of the principles involved.
MS La Moreaux
TL;DR
Faraday's Law versus Motional Emf
Visualize a rectangular bare wire circuit with one side loose so that it can slide along the adjacent sides and thereby change the size of the circuit. There is a static magnetic field orthogonal to the plane of the circuit and linking the circuit. There will be a motional emf in the moving wire, due to its motion through the magnetic field.
Faraday's Law states that the changing magnetic flux linking the circuit results in an emf in the circuit. This would be in addition to the motional emf, since the two principles are independent of each other. The value of the motional emf is equal to the value given by Faraday's Law, and therefore the total emf would be twice the actual value.
What is the resolution of this contradiction?
MS La Moreaux said:
TL;DR Summary: Faraday's Law versus Motional Emf
Since you have stated in your previous threads that you have a BSEE degree from the University of Michigan, please post your mathematical analysis of this setup. It would help if you could also post a diagram of it, but it's simple enough that we can probably figure it out as long as you define all of your terms and variables in your mathematical analysis. Please be sure to use LaTeX when posting math at PF (see the LaTeX Guide below the Edit window). Thanks.
EDIT/ADD: Also, if there is no initial current in the wire loop and the B-field piercing the loop is static, what would cause a force to move the 4th side wire of the loop?
You assume a fixed magnetic field, but if you change the area of your rectangular short circuit, the number of lines inside the loop will remain constant, while lines you assume would then be included inside the loop, will actually be pushed away as the perfect conductor moves.
Faraday's Law is
emf = - d(phi)/dt = lvB, where l = length of the moving wire, v = its speed, phi = the magnetic flux linking the circuit, and B = the magnetic field intensity
The motional emf is given by
emf = lvB.
The wire is moved by an external mechanical force.
The number of magnetic field lines inside the loop changes as the area of the circuit changes. I am not assuming a perfect conductor.
$$EMF = -\frac{d\phi}{dt} = lvB$$
http://labman.phys.utk.edu/phys222core/modules/m5/motional_emf.html
Please post the math that shows that there is an issue...
Which does work on the system.
Thank you berkeman for the LaTex and the diagram. I was unable to practice LaTex as described in the LaTex guide.
Physicists seem to have trouble distinguishing math from physics. There is no issue with the math. The issue is with its interpretation. Here we have two identical results from two independent principles, which is no surprise, because the two calculations are identical. It defies logic to suppose that they both apply.
Please use math instead of words...
I will send you some tips for posting using LaTeX...
The LaTex guide states that I can practice using the "Preview" button. This button did not work for me. I did not want to post something using LaTex without seeing what it looks like.
Math is not physics. Physics cannot be understood only in math terms. It involves concepts which can be expressed in math, but not understood in terms of math. Two quantities may be equivalent in terms of math, but not equivalent in terms of physics. For example, torque and work have mathematically equivalent units, but they are not physically equivalent.
This thread is paused temporarily while I try to help the OP learn to use LaTeX...
I also have this problem. I am not sure if it is a browser issue or something else. However, you can use a website such as https://www.quicklatex.com/ to preview your LaTex before you post it.
Thanks Drak for the helpful tip. Thread is reopened so the OP can post their work.
Yes, thank you Drakkith.
Let me restate the problem. We have a circuit with an emf. We know the correct value of the emf. But there are two independent, conflicting, explanations for the emf. It seems obvious to me that one of them has to be wrong.
They are not at all independent. How are they conflicting? With brushes the geometry is not fixed and so the integral statement of Faraday.s Law is problematic. One needs to actually understand what one is doing.
How are they conflicting? They are two principles both claiming to be responsible for the emf. That is equivalent to two people claiming to have authored a book, not being coauthors. I certainly believe that they are independent. One is based upon the definition of the magnetic field. I do not know what the other is based upon. I suspect it is nothing. I believe that I understand it completely. I do not understand what the rest of your post is stating. Could you elaborate?
One last chance. Post the math behind your claim of a problem, or this thread is done.
What math? All the math that relates to this case is above. It is not about math. There is no problem with the math. I believe that we should all agree that the math is correct.
Above where? Send me a PM (private message -- click on my avatar and Start a Conversation) that points to the math ambiguity that you alluding to, and we can reopen this thread. It's closed for now.
  • · Replies 27 ·
