A question about metric compatibility equation
  • Context: Undergrad
  • Thread starter Thread starter Jianbing_Shao
    Metric
The discussion centers on the constraints required for a connection to be metric compatible in the context of general relativity (GR) and its extensions. A metric-compatible connection satisfies the equation $$\nabla_\rho g_{\mu\nu}=0$$, which allows for the derivation of the Levi-Civita connection. However, the presence of torsion complicates this relationship, as an arbitrary connection can be expressed as a sum of the Levi-Civita connection and a torsion component. The conversation highlights the distinction between metric-compatible and non-metric-compatible connections, emphasizing that the latter does not necessarily have to be torsion-free.
  • Understanding of vector fields and scalar fields in differential geometry.
  • Familiarity with the concepts of metric compatibility and torsion in general relativity.
  • Knowledge of the Levi-Civita connection and its derivation from metric compatibility.
  • Basic understanding of partial differential equations and their applications in physics.
  • Study the properties of the Levi-Civita connection in detail.
  • Explore the implications of torsion in Einstein-Cartan theory.
  • Investigate the nonmetricity tensor and its role in connection theory.
  • Learn about the mathematical techniques for solving systems of partial differential equations in the context of GR.
The discussion is beneficial for theoretical physicists, mathematicians specializing in differential geometry, and researchers exploring advanced concepts in general relativity and its extensions.
Jianbing_Shao
TL;DR
metric compatibility equation, connection, constraint
We all know that The gradient of a scalar-valued function ##f(x)## in ##IR^n## is a vector field ##V_\mu(x)=\partial_\mu f(x)##, Such a vector field is said to be conservative. Not all vector fields are conservative. A conservative vector field should meet certain constraints ##curlV_\mu(x)=0##.
In the discussion of a vector field ##V(x)## , If we take the partial derivative of this vector field we can get ##n## matrix function ##A_\mu(x)##.
\partial_\mu V(x)=A_\mu(x)V(x)
$$If matrix functions ##A_\mu(x)## are continuously differentiable with respect to all variables. then we will find that only when$$
R_{\mu\nu}= \partial_\mu A_\nu-\partial_\nu A_\mu+[A_\mu , A_\nu]=0
$$ then there exist a matrix function ##G(x)## which satisfy: ##A_\mu(x)=\partial_\mu G(x)G^{-1}(x)##.(we can find the proof of this conclusion in the book 'Product Integration, Its History And Applications'P41) also we can get: ##V(x')=G(x')G^{-1}(x)V(x)##.
In general relativity, we calculate a Christoffel connection ##\Gamma(x)##(torsion free)from a metric ##g(x)## using the metric compatibility equation ##\nabla_\rho g_{\mu\nu}=0##. the metric compatible connection ##\gamma(x)## is not necessarily torsion free. From the discussion above, we can say that if the matric ##g(x)## is a matrix function, the metric compatible connection ##\gamma(x)## we get should also satisfy certain constraints. then what is it?
If you consider extensions of GR, where the affine connection is not torsion free, you need additional equations determining the torsion. The most natural theory is Einstein-Cartan theory, which you get from gauging Poincare symmetry of SR and include, e.g., Dirac-fermion fields. Then you get a connection that is metric compatible but necessarily with torsion. Treating the usual macroscopic case, where you have only scalar fields (to describe matter in terms of fluid dynamics) and a massless vector field (to describe electromagnetic fields), you get standard GR.
I am not discuss the connection with torsion, I only want to say that a metric compatible connection is not necessarily torsion free.
The problem here is just that if you try to calculate a connection from a metric, then the connection should meet certain constraints. just like you can get a vector field from a scalar field. the vector field should be conservative(curl of the vector field is 0). this constraint just comes from the fact that the nunber of components of a vector field is bigger than a scalar field., the nunber of components of a connection is bigger than a metric, so the connection we get from a metric should also meet some constraints..
so what is such a constraint.
Perhaps my question can be expressed in another way: from the example of the relationship between a conservative vector field which corresponds to a scalar field and an arbitrary vector field. I think an arbitrary connection field perhaps is not always a metric compatible connection.
So what is the distiction between a metric compatible connection and a non-metric compatible connection.
Indeed, connection doesn't have to be torsion-free. However if it isn't torsion free, then it is an independent variable from the metric in theory. You can always put a connection with torsion in the form
$$\omega^{ij} = \tilde{\omega}^{ij} + K^{ij}$$
Where K is the contorsion tensor, dependent on torsion, and ##\tilde{\omega}## is the torsion-free connection of the same metric. So therefore you have a choice, either to have metric and connection as independent variables, or metric and torsion(because contorsion directly depends on torsion, and therefore you can find the connection if you know the torsion). So you cannot get connection directly from the metric in this case, is what I'm saying.
In this case you still have the metric compatibility condition. However, you can even choose to not have metric compatibility either. In that case, a new tensor will arise, similar to torsion called non-metricity, which will describe this deviation from metric compatibility, so you'll have another extra variable in the theory as well.
Edit: To add to the answer to your question if I understood you correctly, you want to know the restrictions that allow connection to be determined from the metric? In that case the answer is metric compatibility and the torsion zero constraint. With those two, you can derive the formula for connection that is determined completely by the metric, usually called Levi-Civita connection.
Yes ,it is just what I want to know,
From the discussion about the differential equations in mathematics, If the connection in the differential equations such as metric compatibility equation is arbitrary, we can not always find a metric (matrix function) then the pair (metric, connection) can satisfy the equation. So I want to know the restrictions on the connection that allow a connection to be metric copatible.
A "metric-compatible connection" satisfies $$\nabla_{\!\lambda\,} g_{\mu\nu} ~=~ 0 ~.$$This equation is sufficient to determine the symmetric components of the connection. (Count the number of possible index values in the equation, and in the symmetric part of the connection.)
Try doing the usual computation by permutation of indices -- you'll find that the symmetric part of the connection contains extra terms involving the skewsymmetric part of connection. However, the skew part remains unspecified by this procedure. Something else must be introduced to specify the skew part.
Thanks for your reply.
From metric compatibility equation $$\nabla_\lambda g_{\mu\nu}=0$$ we can calculate a Levi-Civita connection, and the torsion part can not be totally determined by this equation.
Then does it means that an arbitrary connection can be expressed with a Levi-Civita connection and a torsion? Then for an arbitary connection we always can find a metric and if we substitude the two into the equation. the equation is true?
I'm not sure you understood what I wrote in the first part of my reply. Like @strangerep mentioned, the metric compatibility equation determines the symmetric part of connection, and since Levi-Civita connection is by definition symmetric, it is always completely determined by this equation -given the metric-. If the connection isn't symmetric, then there is torsion present, and torsion influences connection, and like I wrote in the previous reply, any connection can be represented by a sum of Levi-Civita connection and torsion part(that is the contorsion tensor).
Obviously, if you somehow had torsion defined, and full connection defined, then in principle, knowing those two would be the same as knowing the Levi-Civita connection, so your question then becomes, if you know the Levi-Civita connection components, can you determine the metric? Sure, it's integrating a system of linear PDEs, but in practice you never have that. Sometimes that system is difficult, sometimes not so difficult, but your question then becomes, whether you can solve a linear system of PDEs. You can consult PDE theory about that. If you have both torsion, and the full connection(both symmetric and anti-symmetric part), that is metric compatible, you can solve for the metric.
In practice you never do that. You have field equations which are Einstein equations which are solved for the metric, but in that case the connection is already Levi-Civita. If torsion is present, then instead of one tensor equation(which is the Einstein equations), you also have another equation that determines torsion. That system is much more difficult to solve, as you can imagine, but by solving it, you find both connection and the metric, which are metric compatible(or torsion and metric, as I mentioned earlier).
Not quite. You can calculate the symmetric part of the connection. (Did you attempt the exercise I suggested? I guess not, but you should. The calculation is... rather basic, alas.)
The Levi-Civita connection is
$$\frac12\, g^{\lambda\sigma} \Big( g_{\sigma\mu},_\nu + g_{\nu\sigma},_\mu
- g_{\mu\nu},_\sigma \Big) ~.$$ However, symmetric part of the most general metric-compatible connection is $$
\Gamma^\lambda_{~(\mu\nu)}
~=~ \frac12\, g^{\lambda\sigma} \Big( g_{\sigma\mu},_\nu + g_{\nu\sigma},_\mu
~+ g^{\lambda\sigma} g_{\mu\alpha} \Gamma^\alpha_{~[\sigma\nu]}
~+ g^{\lambda\sigma} g_{\alpha\nu} \Gamma^\alpha_{~[\sigma\mu]} ~.$$ The torsion ##\Gamma^\lambda_{~[\mu\nu]}## is not determined by metric compatibility.
Jianbing_Shao said:
for an arbitrary connection we always can find a metric and if we substitude the two into the equation.
That would be an overdetermined system of partial differential equations (i.e., many more equations than unknowns). That system might, or might not, have a solution.
Thanks for your explanation.
I think my question perhaps can be expressed in such a way: Are all connections metric comatible? If I correctly understand your opinion, the conclusion is uncertain,
My discussion is based on the theory about PDEs in mathematics. If we start from a vector field ##V(x)##, we can get a connection using equations:
But from the equations above, we also can express vector using connection. In Sean carroll's book, he uses parallel propagrator ##P(x.x_0)##(path ordered product) which is generated with ##A_\mu(x)## to describe the parallel transport of a vector according to the equation.
If given an arbitrary connection. the solution of the equation is $$V(x)=P(x.x_0)V(x_0)=P\exp\left(\int_x^{x_0}A^\mu dx^\mu\right)V(x_0)$$
and we can find that only if the ##R(A)## is zero, then ##P(x.x_0)## is path independent. so we can find a vector field can satisfy the equations. if ##R(A)## is not zero, then the equation only can describe a vector moving along a particular path. it is impossible to find a vector field which can satisfy the equation above,
Similarly we also can use parallel propagator to describe the metric from the metric compatibily equations. but the problem is if the curvature of the connection is not zero, the parallel propagrator we get is path dependent, then how to get a path independent metric using a path dependent parallel propagrator. In most cases I'm sure it is impossible. if it is possible then the connection should meet some constraints.
I'm not sure if the constraints I'm talking about is the same as you mentioned.
In the gauge theory of the Poincare algebra this "something else" is the field strength of the spatial translations. Putting this to zero enables you to (1) solve for the spin connection and (2) to remove the local translations in the algebra in favour of general coordinate transformations. (See e.g. https://www.physicsforums.com/insights/general-relativity-gauge-theory/ ; maybe this adds something for TS)
Actually, there are no constraints. In any 4D spacetime with a symmetric metric ##g##, the most general connection ##\Gamma## decomposes in a coordinate basis as:$$\Gamma{}^{\alpha}{}_{\mu\nu}=\left\{ _{\mu\nu}^{\alpha}\right\} +\frac{1}{2}\left(T^{\alpha}{}_{\mu\nu}+T_{\mu}{}^{\alpha}{}_{\nu}+T_{\nu}{}^{\alpha}{}_{\mu}\right)+\frac{1}{2}\left(Q^{\alpha}{}_{\mu\nu}-Q_{\mu}{}^{\alpha}{}_{\nu}-Q_{\nu}{}^{\alpha}{}_{\mu}\right)\qquad\text{(General connection; 64 components)}$$with:$$\left\{ _{\mu\nu}^{\alpha}\right\} \equiv\frac{1}{2}g^{\alpha\lambda}\left(g_{\lambda\mu,\nu}+g_{\lambda\nu,\mu}-g_{\mu\nu,\lambda}\right)\qquad\text{(Levi-Civita/Christoffel})$$and where:$$g_{\mu\nu}=g_{\nu\mu}\qquad\text{(Metric tensor; 10 components)}$$$$T^{\alpha}{}_{\mu\nu}\equiv\Gamma{}^{\alpha}{}_{\mu\nu}-\Gamma{}^{\alpha}{}_{\nu\mu}\qquad\text{(Torsion tensor; 24 components)}$$$$Q_{\alpha\mu\nu}\equiv\nabla_{\alpha}g_{\mu\nu}\qquad\text{(Nonmetricity tensor; 40 components)}$$Note that all 74 combined components of the metric and general connection ##\left\{ g,\Gamma\right\} ## are expressed entirely in terms of the 3 tensor fields ##\left\{ g,T,Q\right\} ##. These fields may in general be freely specified (as long as the metric remains invertible) without encountering any inconsistencies or constraints to be satisfied. Of course, torsion and nonmetricity do lead to geometric differences compared to Riemannian spacetimes: parallelograms don't close and and vector lengths change under parallel transport:
(from https://www.mdpi.com/2218-1997/5/7/173/pdf )
But these differences can be useful for physics: one important historical example is the invention of gauge theory by Weyl in 1918 that is founded on nonmetricity, where he made ##Q_{\alpha\mu\nu}=A_{\alpha}g_{\mu\nu}## a function of the the electromagnetic vector potential ##A_{\alpha}##.
Thanks a lot!
It is very interesting and I still have some questions here:
(1); In QFT, the connection can be expressed as: ##\Gamma_\mu=A_\mu^i T^i##, So the decomposition of connection has any relationship with the classifying the connection with the generators of Lie group.
(2). You say 'Actually, there are no constraints'. Does it means that if we input an arbitrary connection into the metric compatibility equation, then will output a metric field.
then if the input is the general connection ##\Gamma##, ouput should be ##g_{\nu\mu}##.
if the input is ##\left\{ _{\mu\nu}^{\alpha}\right\}##, then output ##g'_{\nu\mu}##
if the input is ##T^{\alpha}_{\mu\nu}##, then output ##g''_{\nu\mu}##
if the input is ##\left\{ _{\mu\nu}^{\alpha}\right\}+T^{\alpha}_{\mu\nu}## ,then output is ##g'''_{\nu\mu}##......
We can input different elements into the equation, then what is the difference between those output.
From what @renormalize wrote in his post #15 you can see that a general connection depends on three tensors, metric, torsion and non-metricity. This connection is not a solution of metricity equation in general. Connection is a structure imposed on the manifold that in principle is imposed independently of the metric.
If you ask what kind of a metric you get if you define a connection using the metricity condition, the answer is, you find a metric that is compatible to this connection. In principle, a general connection does not satisfy the metricity condition. If you set in those equation that ##Q_{\alpha\mu\nu} = 0## you find a connection that is metric-compatible. Metric-compatibility is a condition that you impose on the metric and connection, it is not an equation that defines metric or connection.
If you impose metricity condition, that is, ##\nabla_{\mu}g_{\nu\rho} = 0##, then you ask yourself, how do you get the metric from there. The point is that, in general, you don't get the metric from there. In order to get the metric, you also have to define the torsion tensor, because with only metricity in place, metric and torsion are two entities that independently govern the connection. Or you can reverse it and say that torsion and connection govern the metric. But connection by itself doesn't.
Another way to say this is that a connection and a metric on a manifold are two different types of structures. The metric computes the inner product of tangent vectors and a connection defines how you parallel transport vectors.
You can define a connection on manifold without a metric and vice versa. But, it's a nice property if you have defined both that when you parallel transport two tangent vectors, their inner product remains the same, but it isn't mandatory.
Jianbing_Shao said:
...if the input is the general connection ##\Gamma##, ouput should be ##g_{\nu\mu}##.
Getting the metric from the general connection requires integrating an involved system of first-order partial differential equations. But differentiation is much easier than integration! So instead, go the in opposite direction and consider the general connection ##\Gamma## to be output from the given input tensors ##\left\{ g,T,Q\right\} ##:$$\left\{ g,T,Q\right\} \Rightarrow\Gamma,\quad\left\{ g,0,0\right\} \Rightarrow\Gamma',\quad\left\{ g,T,0\right\} \Rightarrow\Gamma'',\quad\left\{ g,0,Q\right\} \Rightarrow\Gamma''',\quad\text{etc.}$$The differences between the various output connections can then be simply read-off from the first equation in post #15. Also note that we are free to set ##g## to be the flat metric ##\eta## and build connections strictly from the torsion ##T## and/or nonmetricity ##Q##. Such connections give rise to various teleparallel (but flat) analogs of curved Riemannian spacetime.
In my experience, textbooks on GR usually don't spend too much time on why you'd want on physical grounds that a connection is metric compatible.
Thanks a lot:
In most cases differentiation is easier than integration, but in cases such as ##expA(x)##(##A(x)## is a matrix function ), differentiation is also very complicate and in fact we probably can not get an exact result.
Although parallel propagator (it can be regard to be a integration of connection) is very complicate, but at first the differentiation of parallel propatator is very simple, although it is a product of exponents of matrix.
From parallel propagator we also can get property of path dependent.if the curvature of connection is not zero. just like the integral of a vector field whose curl is not zero will be path dependent. I think it is just why the reason why not all connections are metric compatible.
At last the parallel propagator of ##P\exp\left(\int_x^{x_0}\left\{ _{\mu\nu}^{\alpha}\right\} dx^\mu\right)## and ##P\exp\left(\int_x^{x_0}\left(\left\{ _{\mu\nu}^{\alpha}\right\}+T^{\alpha}_{\mu\nu}\right) dx^\mu\right)## is very complicate.
usually we can't find out the exact relationship between them.
So I think the integrational method perhaps is very important , and we also can use it to prove your result
thanks a ltot.
Yes, but perhaps if we figure this out, I think it may help us to understand GR more clearly.
thanks a lot
Metric and connection are two different structures, and if we make it clear to what extent the two are connected from the metric compatibility equation I think perhaps it is very interesting.
Jianbing_Shao said:
thanks a ltot.
Two reasons I can think of:
- ##\nabla_{\rho} g_{\mu\nu}=0## is the covariantization of the condition ##\partial_{\rho} \eta_{\mu\nu}=0## on the Minkowski metric in Cartesian coordinates.
- Physical observables depend on inner products, e.g. the energy of a particle. Without metric compatibility, these observables would depend on the specific path (the "history") taken, which in a lot of cases is not desirable.
Thanks a lot:
Yes, if ’observables would depend on the specific path (the "history") taken, which in a lot of cases is not desirable‘。The property of depending on the specific path is path dependent.
As a scalar, if it's movement is path dependent, it perhaps a result of vector field with non-zero curl. If a vector's movement is path dependent, it depends on a connection field whose curvature is not zero.
And I also think that the metric compatibility eliminate some path dependence of a vector's movement in the space. So I think the metric compatibility is a constraint on the connection.
but I don't know how.
I still have a question.
In GR, if we start from a flat metric ##\eta_{\mu\nu}##, we will get a zero connection, then a zero curvature. But if we start from a zero-curvature connection. then it is not necessary to demand that the connection must be zero, then if we using such connection, from the metric compatibility equation, then the metric compatible to the connection usually is not ##\eta_{\mu\nu}##, then I want to know that from a zero-curvature connection, what are the three parts of the general connection. and if the corresponding metric must be ##\eta_{\mu\nu}##.
Starting from the flat spacetime metric ##\eta{_{\mu\nu}}## (in cartesian coordinates) gives a zero Levi-Civita/Christoffel symbol, ##\left\{ _{\mu\nu}^{\alpha}\right\}=0##, resulting in vanishing curvature ##R^{\alpha}{}_{\beta\mu\nu}=0##. But even when spacetime is flat it can still carry a general connection ##\Gamma## containing torsion ##T## and/or nonmetricity ##Q## (see again the first equation of post #15). So the most general connection on flat spacetime in cartesian coordinates will be ##\Gamma{}^{\alpha}{}_{\mu\nu}=\frac{1}{2}\left(T^{\alpha}{}_{\mu\nu}+T_{\mu}{}^{\alpha}{}_{\nu}+T_{\nu}{}^{\alpha}{}_{\mu}\right)+\frac{1}{2}\left(Q^{\alpha}{}_{\mu\nu}-Q_{\mu}{}^{\alpha}{}_{\nu}-Q_{\nu}{}^{\alpha}{}_{\mu}\right)##. And the flat metric ##\eta## is perfectly consistent with this general connection ##\Gamma## by its very construction, with ##\nabla_{\alpha}\eta_{\mu\nu}=Q_{\alpha\mu\nu}## (metric-noncompatible for ##Q\neq0##, metric-compatible otherwise). So to answer your question: yes, in flat spacetime with a general connection ##\Gamma##, the corresponding metric must be ##\eta{_{\mu\nu}}##. How could it be otherwise? Flat spacetime is equivalent to a flat metric!
Thanks for your reply:
Perhaps there is some difference about how to comprehend metric compatible. In my opinion, metric ##g## is compatible with ##\Gamma## just means that if we put ##g## and ##\Gamma## into metric compatibility equation. the equation is true.
So I think that it is possilbe that there exist a zero-curvature connection and a metric which is not ##\eta## can make metric compatibility equation work.
If I don't misunderstand your opinion. a general connection with zero Levi-Civita connection is compatible with flat metric ##\eta##, To me this means that if we put the general connection and ##\eta## into the metric compatibility equation, the equation is true. Can you prove it?
  • · Replies 24 ·
  • · Replies 38 ·
