A question about operator power series
14 replies · 3K views
Nitram
Hi All,
I've been going through Shankar's 'Principles of Quantum Mechanics' and I don't quite understand the point the author is trying to make in this exercise. I get that this wavefunction is not a solution to the Schrödinger equation as it is not continuous at the boundaries and neither is its first derivative. However, I don't see how this fits together with the rest of the question. What is the significance of the operator series not converging and what is the paradox that the author speaks of? An explanation in simple terms would be really appreciated!
You could write the ##U(t)## as an exponential power series
##\displaystyle\exp (x) = 1 + \frac{1}{2!}x + \frac{1}{3!}x^2 + \dots##
with ##\displaystyle x=\frac{i}{\hbar}\left(\frac{\hbar^2 t}{2m}\right)\frac{d^2}{dx^2}##,
possibly by first setting units where ##\hbar = m = 1## to make the equations simpler. Then operate with that series form operator on the function ##\psi (x,0)##, and show that the obtained power series of ##\psi (x,t)## does not converge for all combinations of ##x## and ##t##. You can also draw mathematica plots for several partial sums with an increasing number of terms to show that those don't approach the correct function.
Thanks for the reply. I have tried the expansion and believe I can show that the operator series does not converge but I don't understand what the significance of this result is. Does it mean that because the series does not converge that the operator has no physical reality for that particular wavefunction? Or have I got it totally wrong?
The wave function given is often claimed to describe a quantum object permanently confined to a finite region of space. However, we are also told that wave packets confined to a finite region of space must spread, i.e., the region they occupy must get wider with time. The wave function given appears to be a counterexample to that claim, hence the "paradox".
The significance of the operator series not converging is that it means the wave function given is actually not a physically possible one. So the fact that it does not "spread" with time is not a problem, since it can't be physically realized anyway. For any wave function that can be physically realized, i.e., any wave function for which the operator series does converge, the region occupied by the wave function will spread with time.
Ok, so it seems that even the initial state ##\psi (x,0)## in that question doesn't have the correct boundary condition of approaching ##0## when ##x\rightarrow\pm L/2##.
Forming power series of ##U(t)## up to 3rd, 10th or 100th order and operating on the ##\psi (x,0)## where I chose ##L=1##, ##\hbar = 1## and ##m=1##, the resulting ##|\psi (x,1)|^2## look like this:
3rd order:
10th order:
100th order:
(the images can be expanded by clicking on them) This doesn't look like it is approaching a function with same normalization as the initial state ##\psi (x,0)##.
I think the textbook must have a typo there and meant to have ##\cos## instead of ##\sin##, since ##\cos## is the function that goes to zero at ##\pm \pi / 2##. Either that or they meant the interval to be ##0 \le x \le L##.
What about the eigenfunction of the Hydrogen atom?
If you make a wavepacket that describes an electron having gotten enough energy to escape the proton's electric field in an H atom, it will probably get wider with time. The question is about a free particle and one locked between hard boundaries. A wave packet in something like a harmonic oscillator potential will not spread indefinitely no matter how much energy you give it (there's no finite "escape velocity" in that potential field).
All of the electron orbital wave functions for the hydrogen atom already go all the way to infinity; they are not confined to a finite region of space. The probability amplitude gets very, very small once you get significantly outside the Bohr radius, but it never goes to zero.
I think what the author wants to teach the students with this exercise is that the given function is not in the domain of the Hamiltonian in ##\mathrm{L}^2([-L/2,L/2])## and thus the operator time-evolution operator ##\hat{U}(t)=\exp(\mathrm{i} \hat{H} t)## cannot be naively applied.
The right procedure is that you start with a complete set of energy eigenfunctions, which are given by
$$u_{n}^{(+)}(x)=\sqrt{\frac{2}{L}} \cos[(2n-1) \pi x/L], \quad u_{n}^{(-)}=\sqrt{\frac{2}{L}} \sin(2n \pi/L).$$
Then you can expand any ##\mathrm{L}^2([-L/2,L/2])## function wrt. these eigenstates
$$\psi(x)=\sum_{n=1}^{\infty} [c_n^{(+)} u_n^{(+)}(x) + c_n^{(-)} u_n^{(-)}(x)]$$
Then the time evolution operator can be "unitarily continued" to all ##\mathrm{L}^2([-L/2,L/2])## functions via
$$\hat{U}\psi (x)=\sum_{n=1}^{\infty} [c_n^{(+)} u_n^{(+)}(x) \exp(\mathrm{i} E_n^{(+)}t)+ c_n^{(-)} u_n^{(-)}(x)\exp(\mathrm{i} E_n^{(-)t})],$$
with the energy eigenvalues
$$E_n^{(+)}=\frac{m}{2} \left (\frac{(2n-1) \pi}{L} \right)^2, \quad E_n^{(-)}=\frac{m}{2} \left (\frac{2n \pi}{L} \right)^2.$$
This operator can, however not calculated using the exponential series applied to ##\psi## since ##\psi## is not in the domain of ##\hat{H}## as a self-adjoint operator.
Yeah, that's the same what the integral form TDSE I wrote about would predict, too. And the function ##\psi (x,0)## can then even be discontinuous on an infinite set of measure zero and still produce some result when propagated.
But then you'd have not the trouble the author wanted to display. Then it's very simple, because then it's an energy eigenfunction, and the exponential series is very easy to calculate.
This was exactly what I was looking for, thank you! Thanks to everyone who replied also, it was all very helpful.
