A question about power, and photons
  • Thread starter Thread starter cupcuppycup
    Photons Power
The discussion revolves around calculating the battery life of a handheld gaming device with a specific pixel density and power consumption. The device has a 5V, 7 watt-hour battery and a screen measuring 2x3 inches with 120 pixels per inch. It is questioned whether the device can last a week with daily use of 60 minutes in a physics class, considering each pixel is lit by a photon emitted from an electron. Participants are encouraged to share their attempts at solving the problem to receive guidance. The focus remains on understanding the relationship between power consumption, battery capacity, and usage duration.
cupcuppycup
a handheld gaming device has 120 pixels per inch on its 2X3 in screen and uses a 5V, 7 watt*hour battery to power it. if each pixel is lit by a photon that is emitted from one electron flowing across the diode, will it last the whole week if you play it just in physics? (physics is 60 minutes each day for five days a week and assume a photon lasts 1 nanosecond)
welcome to pf!
hi cupcuppycup! welcome to pf! :wink:
show us what you've tried, and where you're stuck, and then we'll know how to help! :smile:
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
