MHB Discover the Strange Pattern in Powers: A Question About Calculating Powers
  • Thread starter Thread starter Angel11
The discussion revolves around the observation of a pattern in the powers of integers, specifically how the differences between consecutive squares yield a constant second difference of 2. The user calculated the squares of numbers from 1 to 4 and noted the differences: 3, 5, and 7, leading to the second differences of 2. This pattern relates to the properties of quadratic functions, where a constant second difference indicates a quadratic relationship. The conversation highlights the connection between discrete sequences and their mathematical properties, emphasizing the significance of second differences in identifying quadratic functions. Understanding this concept is foundational in mathematics and calculus.
Angel11
Hello again,it has been a few minutes before my last thread and i am also pleased of its reply so thank about it,but i remembered another question i had,this time about powers.
One day i was calculating the powers of 1,2,3 until 10.This day i realized something strange.
1^2=1, 2^2=4, 3^2=9, 4^2=16...
so i did 4-1=3, 9-4=5 and 16-9=7...
and then i realized this:5-3=2 and 7-5=2... my question is why did it end up the number 2
so the next day i instantly asked my math teacher about it and he told me that this is already found but i am to young to understand why.So now i am asking help here (although i still think i won't understand since i think it will be complicated)
P.S I am sorry if you didn't understand the calculation but it was tough for me to explane it
Thank you
Mathematics news on Phys.org
1 + 3 = 4
1 + 3 + 5 = 9
1 + 3 + 5 + 7 = 16
1 + 3 + 5 + 7 + 9 = 25
Do you see where the '2' is coming from now?
Thank you
$$(x+1)^2-x^2=2x+1$$
$$x^2-(x-1)^2=2x-1$$
$$2x+1-(2x-1)=2$$
Thank you
I like the way you are investigating how things work on your own. (Yes)
What you've discovered here is closely related to a result from the calculus. When the second derivative of a function is a constant, then the function will be quadratic. But, let's look at the discrete version. Suppose you are given the sequence:
5, 8, 14, 23, 35, 50, ...
And you are asked to find the $n$th term.
So, you look at the "first difference", that is, the difference between successive terms, and you find:
3, 6, 9, 12, 15
Then you look at the "second difference", that is the difference between successive terms of the first difference, and you find:
3, 3, 3, 3
So, we find a constant second difference, and we may state that the $n$th term of the sequence, which we'll call $a_n$, will be a quadratic in $n$:
$$a_n=An^2+Bn+C$$
To determine the unknown coefficients $(A,B,C)$, we may construct a system of equations based on the first 3 terms of the sequence, and their given values:
$$a_1=A+B+C=5$$
$$a_2=4A+2B+C=8$$
$$a_3=9A+3B+C=14$$
Solving this system, we obtain:
$$(A,B,C)=\left(\frac{3}{2},-\frac{3}{2},5\right)$$
And so we may state:
$$a_n=\frac{1}{2}(3n^2-3n+10)$$
What kind of general term do you suppose we'd get if we find the third difference is constant?
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
