A question about relativity of simultaneity
116 replies · 12K views
At their encounter, both S and S' emit a light pulse to the left along the x-axis. These photons propagate together. The same happens to the right.
There is no need to have two photons going in each direction. The meeting between S and S' is a single event, i.e., a single point in spacetime. Emitting a single photon in a given direction from a single event is sufficient. This follows from the postulate of the constancy of the speed of light in any inertial frame, which is being assumed for the problem. Anything you say about a given pair of photons propagating together in your version, can also be said about a single photon in the standard version.
That is correct. The difference is in didactics. That seems to have been the problem in this thread.
If only S' emits a photon (event 1) which subsequently arrives at the end of the train (event 2), then from the point of view of observer S, the coordinates of events 1 and 2 can only be determined via the L-T.
If, on the other hand, each of the observers emits a photon at origin coverage, which propagate together, then it becomes clear why the coordinates of an event also differ in time. Then one can derive the L-T instead of presupposing it.
Huh? It's just an intercept caculation in either frame (albeit a trivial one in one frame). You need to use the invariance of the speed of light, sure, but that's how you derive the Lorentz transforms.
I do not dispute the possibility of a purely mathematical derivation of the L-T in the standard situation. However, I think that the intuitive access, which Einstein's thought experiment shall open, is better served with two complementary photons. The connection with the finiteness of the causal propagation becomes clear. The identity of signal path and (signal)time between two events becomes conscious.
Seems like an unnecessary complication to me, but if it works for you that's fine. It's a rather different claim from "[t]hen one can derive the L-T instead of presupposing it", which you made earlier.
Yes, that was a bit inaccurate, I should have written "instead of presupposing it mathematically."
That's still wrong. You aren't pre-supposing the Lorentz transforms whether you use light pulses emitted only by the train observer or pulses emitted by both train and embankment observers. All the latter does is reinforce the consequence of the invariance of the speed of light by making the case that the parallel pulses should travel side-by-side.
I have assumed the L-T for the conversion of the coordinates of only one light pulse (#93). The L-T must be derived mathematically before. I doubt like DmitryS that Einstein's thought experiment (the "observation" of a light pulse) is helpful for it. But you are welcome to see it differently.
This is not correct. Whether the photon is emitted by S' or S is irrelevant, since, as I have already pointed out, the emission event is a single event (a single point in spacetime), namely, the event at which the worldlines of S and S' cross. So each photon is traveling at ##c## in a known direction from a known starting point, and the ends of the train are traveling at a known speed ##v## in a known direction from known starting points. This is true in both frames, so the coordinates of the reception events can be calculated in both frames independently, without having to make use of any transformation whatsoever.
The positions of the ends of the train (the starting points) are by no means known to both observers. Only if a starting point of one end of the train is fixed for one of the observers, the starting point for the other observer results from the L-T. The L-T is the precondition for this.
In other words: the event 2 of the arrival of the light pulse must be defined for one of the observers, only then it can be said for the second observer by means of L-T when and where it occurs for him.
They don't need to be. Each observer only needs to know that, in his frame, the two reception points are in opposite directions, at equal distances, from the emission point. The emission event alone is sufficient to link things together in both frames because, by stipulation, that event occurs when the two worldlines of the observers (one on the embankment and one at the center of the train) cross.
Einstein's thought experiment is confusing because S is supposed to "observe" two light pulses at the platform, which S' has emitted in the middle of the train.
Btw, this is not Einstein's original thought experiment. In Einstein's original thought experiment, two light pulses are emitted from opposite ends of the embankment (when lightning strikes occur at those places), and are received at the same event by the embankment observer who is halfway between the emission locations. Einstein takes this as a definition of what "simultaneous" means for the embankment observer. He then shows that the same two events (the emission events of the two light pulses) cannot meet the same definition of simultaneity for a train observer who is spatially co-located with the embankment observer at the same instant in the embankment frame that the light pulses are emitted.
You are turning all this around and having light pulses be emitted from the center towards the ends, instead of from the ends towards the center. This still illustrates relativity of simultaneity, but in a different way.
PeterDonis #102:
If the receiving points are at the same distance for one observer, then under no circumstances they can be at the same distance for the other observer.
In other words: If for each of the observers receiving points are at the same distance, they are not talking about the same receiving events.
The emission event is fixed for both observers (0/0), but the reception events are fixed for only one of them. The other one must derive them in theory (in the thought experiment) from the L-T or measure them in practice.
Yes, they can, if the receiving points and their distances are different for each observer, and relative to each observer's frame.
Of course not. That is an obvious consequence of your version of the scenario: the train reception events are a different pair of events from the embankment reception events.
Note that in Einstein's original version, there is only one pair of events because the pair is a pair of emission events, which are simultaneous in the embankment frame by construction. But you could also add to his version a second pair of emission events that were simultaneous in the train frame; these events would of course have to be different from the embankment pair (and this second pair would not be simultaneous in the embankment frame).
Nope. Each one can compute his own reception events simply from the knowledge of the emission event's location in their frame (that it is exactly halfway between the two reception points). Each pair of reception events will be simultaneous in the corresponding observer's frame, but will not be simultaneous in the other frame.
There is no essential difference to Einstein's arrangement: With Einstein, the two emission events at the ends of the train are defined from the point of view of the railroad embankment observer (S).
For the train observer (S'), who passes by S at the time when the emission events take place from the point of view of S (origin coverage at 0/0; 0/0), the emission events can only be determined with the help of the L-T.
Why should I assume with Einstein's arrangement a second pair of light pulses which are simultaneous for S'? That would be other events of the emission than for S.
It is always only about sending light pulses from events to events which are identical for both observers. From the ratio of the lengths of the signal paths (from the view of the two observers) the L-T can be derived.
This is not correct. You do not need to know the Lorentz transforms to be able to derive them from Einstein's thought experiment, as already laid out in posts 75 and 76.
I never denied that Einstein accurately derived the L-T from an introductory "Gedankenexperiment". I only pointed out that it is an abstract-mathematical derivation (cf. #75), where his thought experiment is not very helpful (#99), because it reminds too much of tennis balls (of Newtonian mechanics) (#89).
Well, if you are very rigorous you have to think in terms of the wave front of electromagnetic waves, which always moves with the speed of light in vacuum.
This is the reason why wave fronts (also of spherical waves), which were emitted by observers moving towards each other, propagate together.
A photon cannot overtake another one. If two photons are emitted in the same direction at origin coverage, they propagate together. Even if the respective observer emits his photon in quite certain angle to the axis of motion, they propagate together (compare e.g. the signal paths in the moving light clock).
DmitryS said:
But that is the problem I'm asking about. The relative speed is greater than the speed of light.
As others have noted, it's the closing speed, not the relative speed, that's greater than ##c##.
The person in the center of the train car will still observe the light beam moving at speed ##c##. The person on the embankment will also see the speed of the light pulse as moving at speed ##c##. But he will see the person in the center of the train car moving at speed ##v##. He will observe them moving towards each other at speed ##c+v## but he will not observe either of them moving at a speed greater than ##c##.
The point of this thought experiment starts with the sentence highlighted above. Prior to Einstein it was thought that the embankment observer would see the light pulse moving at a speed other than ##c## so that the two light pulses would have been generated simultaneously according to both observers. The point of the thought experiment is to show that if the speed of light is independent of the speed of its source, then simultaneity is relative rather than absolute.
No, they are defined to happen at the same events at which the ends of the train pass the corresponding points on the embankment (the points where the lightning strikes happen and emit the two light pulses). Those events are invariant.
Wrong. They are defined as above. Since those events take place at the ends of the train, their spatial locations in the train frame are determined by that condition. The train observer can then determine the times of those events in his frame by observing the time on his clock when he receives the light pulses. No LT is required.
I didn't say you should, I only said you could.
Of course, I have already said that.
This is one way of looking at the thought experiments, yes.
Yes, you can derive the LT from the information provided in the thought experiments, since that information (which includes not only the lengths of the signal paths but the times involved, which can be computed from the fact that the speed of light is the same in all inertial frames) is sufficient to determine the coordinates in both frames of all events.
But you are claiming that you need to assume the LT in order to determine the coordinates in both frames of all events. That is false.
You have repeatedly claimed that you need to assume the LT in order to determine the coordinates of some of the events in the thought experiment:
If these claims were true, they would be inconsistent with the claim that Einstein correctly derived the LT from his thought experiment. You can't derive something by assuming it. But that's what you are claiming. You can't have it both ways. Either the LT can be validly derived from Einstein's thought experiment, or it has to be assumed. The former is in fact correct.
This is not true. You've said things like "the emission events can only be determined with the help of the L-T" (in post #106), which is a lot stronger than the claim you now say you were making, and is also incorrect. It is perfectly possible to derive the Lorentz transforms from Einstein's version of the thought experiment. I don't personally find his exposition particularly clear, so here is my version.
A train travelling at speed ##v## passes a stationary embankment of length ##2l##. As the nose and tail of the train pass the end and start of the embankment, respectively, they are struck by lightning. An observer standing at the center of the embankment sees the flashes arrive at his location simultaneously and concludes that the strikes were simultaneous. Can we deduce the Lorentz transforms?
Let there also be an observer on the train. She measures the train's length to be ##2l'##. Both observers zero their clocks when they pass one another, and both measure distance from their own locations. Since both frames are global inertial frames the transform (whatever it is) between the ##x,t## coordinates of the embankment observer and the ##x't'## coordinates of the train observer must take the form$$\left(\begin{array}{cc}A&B\\C&D\end{array}\right)$$
The embankment observer assigns coordinates ##x=l, t=0## to the front strike. The train observer assigns coordinates ##x'=l', t'=T_+'##. Applying our matrix yields:$$\left(\begin{array}{c}T_+'\\l'\end{array}\right)=\left(\begin{array}{cc}A&B\\C&D\end{array}\right)\left(\begin{array}{c}0\\l\end{array}\right)$$from which we deduce that ##B=T_+'/l## and ##D=l'/l##. The rear strike is at ##x=-l,t=0## for the embankment observer and ##x'=-l', t'=T_-'## for the train observer, and the equivalent calculation merely adds that ##T_-'=-T_+'##.
Now we can turn our attention to the events where the train observer receives light from the flashes. A straightforward intercept calculation tells us that the embankment observer assigns coordinates ##x=lv/(c+v), t=l/(c+v)## to the arrival of the pulse from the front while the train observer assigns ##x'=0, t'=l'/c+T_+'##. Again using the matrix on the embankment observer's coordinates and equation this with the train observer's coordinates gives us that ##A=\frac{(c+v)l'+c^2T_+'}{cl}## and ##C=-l'v/l##. For the arrival of the flash from the rear, another intercept calculation tells us that the embankment observer assigns coordinates ##x=lv/(c-v), t=l/(c-v)## and the train observer assigns ##x'=0,t'=l'/c-T_+'## (where we have used our result for ##T_-'##). Again we apply our matrix to the embankment coordinates, recovering that ##T_+'=-l'v/c^2##.
Putting all this together, we have found that the Lorentz transforms expressed as a matrix are$$\left(\begin{array}{cc}l'/l&-l'v/c^2l\\-l'v/l&l'/l\end{array}\right)$$We only need to work out what is the relationship between ##l## and ##l'##. We can do this by noting that the principle of relativity says that the inverse transform must be the same except for the sign of ##v##. Inverting our matrix gives us$$\gamma^2\left(\begin{array}{cc}l/l'&lv/c^2l'\\lv/l'&l/l'\end{array}\right)$$where ##\gamma=\left(1-\frac{v^2}{c^2}\right)^{-1/2}## is the Lorentz gamma factor, and the condition that this is the same except for the sign of ##v## tells us that ##l'=\gamma l## and hence that the Lorentz transform as a matrix is$$\left(\begin{array}{cc}\gamma&-\gamma v\\-\gamma v&\gamma\end{array}\right)$$And multiplying this by the generic coordinates ##(x,t)^T## gives us the usual form.
That is a nothing more than a process of writing down coordinates and deducing a relationship. If that's abstract maths, all of physics is abstract maths.
