Can Double Slit Experiment Results Differ with Two Separate Light Sources?
  • Thread starter Thread starter Thead
    Double slit Slit
The discussion centers on whether the Double Slit Experiment would yield an interference pattern when using two separate light sources aimed at independent slits, each blocked by a barrier. It highlights that interference effects depend on the coherence of light, which is typically enhanced by using a single source. Historical context is provided, noting that the use of two independent sources for interference was first demonstrated in 1967 with lasers. The conversation emphasizes that modern technology has made such experiments more accessible. Ultimately, the coherence of the light sources is crucial for observing interference patterns.
Thead
If you were to take Youngs original Double Slit Experiment, with this slight variation, would you get the same results you would usually expect, i.e. an interference pattern?
The variation is as follows: Instead of one source of light, there are two sources of light, positioned next to each other each aimed directly at independent single slits. Between the slits, there is a barrier running all the way down to separate the two sources of light from each other, resulting in; Source A can only travel through Slit A, and Source B can only Travel through Slit B.
A crude diagram of what I'm trying to explain:
0 = Slit
x =Light Source
| = Solid Barrier Between Light Sources
_ = Detector Screen
. = Ignore (Purely for spacing purposes)
__________
-----0|0-----
|...x | x...|
Interference effects depend upon the coherence of the light; this is usually done by using a single source passed through a pinhole - this improves the spatial coherence of the beam. This improved beam then goes through the double slit.
See http://www.rp-photonics.com/coherence.htmlAnd for some history see: http://en.wikipedia.org/wiki/Young's_interference_experiment
Of course it is possible to use two independent sources to show interference; this was first done in 1967 using two lasers: Pfleegor and Mandel "Interference of Independent Photon Beams". This experiment is much easier to do today.
Thanks for your informative reply, much appreciated.
So I know that electrons are fundamental, there's no 'material' that makes them up, it's like talking about a colour itself rather than a car or a flower. Now protons and neutrons and quarks and whatever other stuff is there fundamentally, I want someone to kind of teach me these, I have a lot of questions that books might not give the answer in the way I understand. Thanks
14K
21K
