A quick conception question Newtonian physics
Acceleration due to gravity is constant at approximately 9.81 m/s² for all objects, regardless of their mass, when air resistance is negligible. Both a stone weighing 1000 kg and a ball weighing 1 kg will experience the same acceleration when thrown upwards with the same initial speed. The argument that a lighter object would have greater acceleration is incorrect. This principle is a fundamental aspect of Newtonian physics. Therefore, the acceleration remains the same for both objects in a vacuum.
quantumtron
i was having an argument with my friend.
He claims that acceleration for object that is lighter, let say a stone (1000kg) and ball (1kg). If we were to throw them up in the sky with the same initial speed, their acceleration would always be 9.81ms^2 (depending on sign conventions). Am i right to say that?
My friend claims that the acceleration for the lighter object would be greater...
You're right. Your friend is wrong (assuming we're neglecting wind resistance).
The rope is tied into the person (the load of 200 pounds) and the rope goes up from the person to a fixed pulley and back down to his hands. He hauls the rope to suspend himself in the air. What is the mechanical advantage of the system? The person will indeed only have to lift half of his body weight (roughly 100 pounds) because he now lessened the load by that same amount. This APPEARS to be a 2:1 because he can hold himself with half the force, but my question is: is that mechanical...
Some physics textbook writer told me that Newton's first law applies only on bodies that feel no interactions at all. He said that if a body is on rest or moves in constant velocity, there is no external force acting on it. But I have heard another form of the law that says the net force acting on a body must be zero. This means there is interactions involved after all. So which one is correct?
Thread 'Beam on an inclined plane'
Hello! I have a question regarding a beam on an inclined plane. I was considering a beam resting on two supports attached to an inclined plane. I was almost sure that the lower support must be more loaded. My imagination about this problem is shown in the picture below. Here is how I wrote the condition of equilibrium forces: $$ \begin{cases} F_{g\parallel}=F_{t1}+F_{t2}, \\ F_{g\perp}=F_{r1}+F_{r2} \end{cases}. $$ On the other hand...
