Proving Linear Independence: Vectors in R^5 and Their Span
  • Thread starter Thread starter NeonVomitt
    Vectors
To determine if at least one of the vectors v1, v2, or v3 is not in the span of vectors a1, a2, and a3, one can analyze the transformation matrix T formed by the coefficients of a1, a2, and a3. Since v1, v2, and v3 are linearly independent in R^5, the rank of the transformation matrix T must be less than 3 for the vectors a1, a2, and a3 to span a space that does not include all of v1, v2, and v3. Reducing T to row echelon form will reveal its rank, helping to confirm whether the span of a1, a2, and a3 can encompass all of v1, v2, and v3. If the rank of T is less than 3, it indicates that at least one of the original vectors is excluded from the span. Therefore, performing the row reduction is essential for proving the claim.
NeonVomitt
Suppose that v1,v2,v3 are linearly independent vectors in R^5 and consider the vectors a1,a2,a3 defined by a1=v1+v2-2v3, a2=3v1+v2+4va, and a3=v1+2v2-7v3. Show that at least one of the vectors v1,v2,v3 is not in the span of the vectors a1,a2,a3.
I am kind of confused. Should I somehow reduce row echelon it? But how would I even set that up given this type of format?
Thank you!
Mathematics news on Phys.org
a=T.v
where
T={{1,1,-2},{3,1,4},{1,2,-7}}
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
