A speaker produces a sound with a frequency of 1000hz. How many waves
A speaker producing a sound at a frequency of 1000 Hz generates 1000 waves per second, resulting in a wavelength of 30 cm. These waves spread out in a spherical pattern from the speaker, similar to rapid blast waves. The number of waves in front of the speaker does not decrease with distance; rather, the frequency remains constant regardless of location. However, the perceived velocity of the waves can change based on the listener's movement relative to the speaker. Thus, the sound consists of a continuous series of waves, not just a single wave.
Justin Kirk
A speaker produces a sound with a frequency of 1000hz. How many waves are traveling in the air in front of the speaker? Does the number of waves decrease as one moves away from the speaker? Is there only the single 1000hz wave moving the air in front of the speaker? This is not a homework question, just an idea of how sound may look. I'm trying to picture in my mind a sound wave.
The speed of sound in air is roughly 300 metres per second. So in one second, your speaker produces 1000 waves that occupy the space from zero to 300 metres in front of the speaker. So each wave must be 300/1000 = 30cm long (about a foot).
Of course the waves don't just travel in one direction, they spread out in a sphere from the speaker a bit like a series of rapid blast waves from an explosion, each 1 foot apart.
Does that help?
Are you asking what the rate is (number per time)? That would be your 1000Hz. The total number of waves is constantly changing.
It's produce 1000 waves per second, regardless of where you are. The frequency you perceive doesn't change with distance from the source (speaker). Velocity, however, does. If you're moving away from or toward the speaker, you're "moving through" the waves faster or slower, so it's as if the waves were going faster or slower.
1000hz does not represent a single wave. 1000hz means 1000 waves per second. So a series of (ideally) spherical waves just keep on expanding from the stereo, alternating between high and low pressure.
  • · Replies 31 ·
  • · Replies 19 ·
  • · Replies 27 ·
