Can a Match be Used as a Conductor in a Triboelectricity Experiment?
  • Context: Undergrad
  • Thread starter Thread starter jaumzaum
    Experiment
The discussion centers on the role of a match in a triboelectricity experiment involving a balloon, hair, and coins. The match, while not a conductor, can still exhibit charge induction due to the polarization effect when brought near an electrified balloon. The coins serve as a low-friction mechanism that allows the match to rotate, facilitating the interaction. The experiment demonstrates that even insulators can experience charge shifts without requiring a direct electric current.
  • Understanding of triboelectric effect
  • Knowledge of dielectric materials and polarization
  • Familiarity with basic electrostatics
  • Experience with experimental physics setups
  • Research the triboelectric series and its implications in experiments
  • Explore dielectric properties of materials and their effects on charge induction
  • Investigate the role of friction in electrostatic experiments
  • Conduct experiments using various insulators to observe charge behavior
Students and educators in physics, experimental physicists, and hobbyists interested in electrostatics and triboelectricity experiments.
jaumzaum
Consider the following experiment. 2 coins are put in the position shown above, with a match above them. A boy scrubs a balloon on his hair and takes the balloon near the match. The match follow the balloon.
The balloon will be electrified by friction, and it will induce opposite charges in the device. But what is the purpose of the match in this experiment? The match is not a conductor (at least I think there is no conductor in a match head), will charges be induced on the match or only in the coin?
So the hair gets a strong positive charge and the balloon gets a string negative charge.
Bringing the balloon close to the match stick pushes electrons in the match stick to the rear and creates a positive end that will be attracted to the balloon.
The fact that this can occur even with a good electrical insulator between them indicates that essentially no electric current is required for this effect.
I wonder what the significance of the coins is?
I would say it works as a gear that rotates the match with low friction.
I didn't know this could occur on insulators at non-extreme electric fields. So we really see an electric current flowing inside the stick in the transitory interval?
I don't think you need a gross movement of charge. Dielectrics have slight local shifts in charge - polarisation - in response to a field.
And if the match isn't perfectly dry, that would make all the difference.
If you're actually doing the experiment, try replacing the match with a piece of plastic tube, e.g. cut from a Q-tip.
  • · Replies 46 ·
  • · Replies 28 ·
  • · Replies 25 ·
  • · Replies 0 ·
