A vehicle has two wheels rolling at different speeds. What forces act on the vehicle as it follows a curved trajectory ?
  • Context: Undergrad
  • Thread starter Thread starter isni
    Speed Vehicle Wheels
The discussion revolves around the forces acting on a vehicle with two wheels rolling at different speeds as it follows a curved trajectory. Participants explore the implications of differential braking in a flight simulator context, focusing on the horizontal forces involved and the mechanics of the vehicle's motion.
  • One participant notes the difficulty in identifying the horizontal force that causes the vehicle to follow a curved path.
  • Another suggests that if the wheels are performing pure rolling, the center of mass (COM) of the wheels will have different velocities, contributing to the curved trajectory.
  • A participant emphasizes the need to understand the forces acting on the vehicle as a whole, questioning the source of the horizontal force.
  • It is proposed that friction forces at the front and rear axles act in opposite directions, influencing the vehicle's forward motion and potential rotation if static friction is overcome.
  • There is a discussion about whether the wheels are locked together via an axle or allowed to rotate independently, with some participants suggesting different configurations like a solid drive axle.
  • One participant draws an analogy between the vehicle's motion and a rod with ends moving at different velocities, questioning the causation of rotation versus correlation.
  • Concerns are raised about the implications of different friction forces on the same axle, particularly in scenarios where one wheel may slip or be on different surfaces.
Participants express differing views on the mechanics of the vehicle's motion, the role of friction, and the configuration of the wheels. No consensus is reached regarding the exact forces at play or the implications of the vehicle's design.
Participants highlight various assumptions regarding the vehicle's configuration, the nature of the forces involved, and the conditions under which the wheels operate, indicating a complex interplay of factors that remain unresolved.
isni
This is not homework, it's a problem I came across while trying to model differential braking for my flight simulator. I cannot really see what force pushes the vehicle horizontally and I would really appreciate a detailed explaination.
If they are performing pure rolling, the velocity of COM of the wheels will be different that causes the curved trajectory.
what you say makes a lot of sense, but it doesn't explain what im mostly interested in, what forces are applied to the vehicle, as a whole, that makes it follow this curved trajectory. There has to be a horizontal force in there and I cannot figure out where it's coming from
You should have a friction force pointing towards the left at the front axle and another one pointing right at the rear axle. If the moments are in equilibrium, the vehicle will go forward. (Vertically in your drawing.)
If the sideway static friction forces of your wheels can be broken (sliding), your vehicle will rotate about the COM (or some other point if the moments of the sideway forces are not equal and opposite), changing the direction of your forces. So as the vehicle still seems to go "forward", the newly rotated vehicle's frame moves sideways with respect to the ground.
But if the two wheels connected by an axle , is the internal force that forces them to remain together, tension?
Wait. You are not suggesting the two wheels are locked together via the axle? You are allowing them to rotate independently, yes?
We're not talking 1964 Buick Skylark with solid axle suspension are we?
One easy arrangement would be a solid drive axle (no differential) attached rigidly to the wheels. One wheel with radius ##2r## on the left and one wheel with radius ##r## on the right.
Probably not a Michelin XGV size 75R-14.
I thought if the velocity of COM of both the wheels is different, it can be treated as rod whose ends have different velocities causing the rod to rotate. It is analogous to that, Right?
Something similar to this except velocity(v) in place of acceleration and axis of rotation outside the both wheels
OR in this question:
Then tension is the internal force in the rod
"Cause"?
If the rod has ends that move at different velocities then the rod will be rotating. But that is correlation, not causation.
If the rod is "rigid" then it will retain its size and shape regardless of the pattern of external forces that is encountered. In practice, "rigid" means that small deformations result in large restoring stresses so that size and shape are approximately preserved.
Flight simulator dealing with 4-wheel vehicle? :oldconfused:
What is the driving force?
What makes the shown angular velocities different?
How the mentioned differential braking works in this specific case?
You beat me to it!! :wink:
If both wheels are connected, one wheel will slip for sure while on different path lengths.
You can have different friction forces on the same axle. Imagine one wheel on asphalt and another one on ice: One has traction, and the other has almost nothing. Worst case scenario, imagine one wheel off the ground: both wheels turn at the same angular velocity but one offers no resistance at all from friction.
  • · Replies 116 ·
13K
11K
9K
