A very simple moments question
  • Thread starter physicals
105 replies · 14K views · last reply
anuttarasammyak said:
I observe different results between us on Fy, vertical component of the force from the wall to the rod.
Yes, different constructs result in different forces. That two constructs agree on Fx, doesn't imply they must agree on Fy as well.
The rigid joint in the inverted L-shape transmits a torque by inhomogeneous forces acting within the joint, purely internally.
In the hinges-only-version this torque transmission is accomplished by inhomogeneous forces from the wall and the diagonal rod, which is not purely internal, and thus can result in different forces at the wall.
And the issue above said is the fracture of the rod itself, not the (y-component of ) fixing force to the wall, Fy. In my understanding, Fy does not depend on 𝜃. The rod may bend down, but it will remain attached to the wall.
Please explain what you mean by ##\theta## when you have a Γ - shaped construction. It's the angle between what two lines?
It seems to me that you replace the original situation in post #1, which has a well-defined angle ##\theta##, with a different situation shown in post #6, where ##\theta## is meaningless, and then discover the obvious conclusion that ##F_y## does not depend on ##\theta## in this different situation!
I would say that the original diagram in post #1 is ambiguous on aspects, that do not affect Fx, which the question is about.
There are different plausible interpretations of the original diagram in post #1. For some Fy does depend on ##\theta##, for some it doesn't. But since Fy is not asked for, that's OK.
The small angle between the wall and the diagonal rod, blue line, in the figure of my #90 you quoted. We can make it infinitesimal.
No. That angle is not equivalent to the angle ##\theta## in any mechanically relevant way.
For the rigid Γ the equivalent of the angle ##\theta## would be an internal angle, not an angle with the wall. Making ##\theta## very small is equivalent to making the rigid joint of the Γ very small, so the internal inhomogeneous forces in the joint transmitting the torque become very large.
... However, in our case we assume a massless rigid-body parts. If we have rigid enough material, design such as #6 @Lnewqban would be all right.
I would like you to study the following link, which shows how internal forces transfer the external load to the wall:
https://www.jlconline.com/Training-the-Trades/beam-stress-and-strain-a-lesson-in-statics_o
Bending stress is frequently avoided because it induces internal tension, compression and shear forces that could sometimes overwhelm the natural resistance of the material forming the structure.
The main reason is the reduced lever length due to the geometry of the cross-sections.
In the OP diagram, the magnitude of internal moment acting on the horizontal member steadily grows from the point of the external load application to the point at which the diagonal brace connects to the horizontal member.
In my diagram of post #6, the magnitude of that internal moment keeps growing (passing the point at which the brace would connect) until reaching the vertical member.
Therefore, the cross-section at that point should be calculated or designed to resist that increased internal bending load.
Yes, my black point means hard fixed for an example by welding. I am not familiar with torque-free hinges. By replacing welding with these hinges can we change forces and torques in the static configuration?
Torque-free hinges are freely articulated or pinned connections between two members of any structure or armature, or between one member and a solid basement, like the ground, or a wall, or a concrete slab.
Those are unable to resist a circular movement with an opposite moment or torque.
Examples can be the above-mentioned hinges of a door, or a bolt in a nut before it reaches its clamping effect, or the blades of an unpowered desk fan.
Please, also see these:
https://skyciv.com/docs/tutorials/beam-tutorials/types-of-supports-in-structural-analysis/
https://web.mit.edu/4.441/1_lectures/1_lecture13/1_lecture13.html
https://eng.libretexts.org/Bookshel...igid_Body_Basics/3.04:_Reactions_and_Supports
Table of types of supports for plane structures in three categories: roller, rocker, link, hinge, and fixed, each with its symbolic representation, reaction forces, and number of unknowns.
Isn't this the proper resolution of forces for the torque about pt P?
Free-body diagram of a rod pivoting at o, hung from a vertical wall at q and tied by a diagonal cable to point p, with weight W hanging from its right end, showing forces F, W and w sinA and the equation F = w tan A.
Which is the same result as when you applied a free body analysis to point "o".
BTW, There is only a perpendicular force to the wall at point "q" by virtue of the initial conditions.
Fy=0
Edit: Fy is not zero due to the torque about point "o". See correction in post 100.
Fy=0
How come you have relocated W to act at point O?
The horizontal distance from P to the hanging mass is what matters.
Yes., thanks, My revised diagram is
Hand-drawn diagram of a vertical wall with points p and q, a horizontal rod meeting a diagonal strut d at point o, a hanging weight W from the rod's end, and labelled forces F and (y+z)W/y at angle A, with the equation F d cos A = (y+z) d w sin A / y and F = 85 Nt.
  • Diagram of a bar hinged at a vertical wall point with a horizontal force F acting at one end, a weight W hanging from the far end, and a diagonal strut from the wall to the hinge; labels include x, y, z, d, A, p, q and the moment equation F x = (x+z) w d sinA / y.
@gleem When we regard O as a point in the massless rigid body composed of the arms y, z, and d, only internal forces act on O. Their total is zero and they produce no momentum of force. This applies to all the other parts of the rigid body except the three points, i.e., p,q and the z arm end tied with the weight, on which the external forces act.
I would like to understand your point of view, which seems to be different from this. I assume you take horizontal bar and diagonal bar as two rigid bodies between which action reaction forces apply. Am I correct?
When we regard O as a point in the massless rigid body composed of the arms y, z, and d, only internal forces act on O. Their total is zero, so they produce no torque. I would like to understand your point of view, which seems to be different from this.
@gleem is taking moments about P, not O. I see no conflict.
That gives the right moments equation, but it is not right as a force diagram. The weight W, applied where it is, is not equivalent to a greater force applied at O.
Why not consider the horizontal bar and the diagonal bar as the system and just write ##(y+z)W=xF##?
haruspex said:
Why not consider the horizontal bar and the diagonal bar as the system and just write (y+z)W=xF?
This is the simplest approach to get what is asked (F) and is also used in the solution in the OP.
But it seems like some posters want to go beyond that, and solve for all force components at all connections. However, the original diagram is just specific enough to get what is asked, so we get different interpretations and results for the other components.
That is the way it is solved in the OP. I thought it instructive to determine the force at pt "o' since the lever arm at point "p" is d. It may not be obvious that W•(y+z) is correct since W is not at "o" like F is.
Ok, but the force at point O due to the suspended weight is W, as you had it in post #98. The error there is that, since the horizontal bar is rigid, there is also a torque ##Wz##. I.e. the force of the weight acting at the end of the bar is equivalent to W acting at O plus a clockwise torque ##Wz## about O.
