A voltage booster without capacitor
  • Thread starter Thread starter Truthlover
    Capacitor Voltage
This discussion centers on the feasibility of powering a 4.8V DC motor using a 1.5V battery without employing an output capacitor in a boost DC-DC converter circuit. Participants emphasize the importance of understanding the role of capacitors in smoothing output voltage and suggest alternative methods, such as using inductors for voltage multiplication. The conversation highlights the challenge posed by the constraint of not using a capacitor, leading to innovative solutions like generating a pulse waveform to drive the motor. Key resources mentioned include the Simple Switcher boost DC-DC circuits from National Semiconductor and the importance of battery discharge characteristics.
  • Understanding of boost DC-DC converter topology
  • Familiarity with output capacitor functions in electronic circuits
  • Knowledge of battery discharge characteristics and efficiency calculations
  • Basic concepts of inductors and voltage multipliers
  • Explore the Simple Switcher boost DC-DC design calculator from National Semiconductor
  • Research the effects of varying output capacitor sizes on circuit performance
  • Learn about alternative methods for voltage boosting, such as using inductors
  • Investigate pulse width modulation (PWM) techniques for motor control
Electronics enthusiasts, hobbyists working on battery-powered projects, and engineers seeking innovative solutions for power management without traditional components.
Truthlover
Hello i just want to know if it's possible to do 5V with a 1.5V battery without any capacitor
Thanks
Thanks
Are you familiar with the boost topology DC-DC? Why do you not want an output smoothing cap? What is the application that you have in mind?
I have to run a 4.8V DC motor with a 1.5V battery. The motor is used to propulse a little car.
Look at the Simple Switcher boost DC-DC circuits at National Semiconductor:
http://www.national.com/analog
Click on the design helper at the right of the page, and input your voltage and current requirements. The calculator will help you design the circuit. You can generally buy the parts from Digikey.com
You should also calculate how long the motor will run on that 1.5V battery. Assume about 85% efficiency for the boost stage (the National calculator may guesstimate the efficiency for you -- I'm not sure if it will), and check the A*Hr rating of the 1.5V battery. BTW, when you spec the input voltages for the calcultor, keep in mind that the range for an alkaline battery is about 1.65V fresh, and 0.8V mostly gone. Other battery types will have different discharge curves. Check the battery manufacturer websites for datasheets.
I think the calculator will provide you with an output capacitor value. I'm still not sure why you don't want to have a cap at the output. If you still have questions after using the calculator, post them here and we'll try to help.
This is very good but i want to know if it's possible tu use the booster without capacitor. it's a constraint.
In example: is it possible to use this boost converter without the cpacitor if not what will happen
You tell us. What is the function of the capacitor in the standard boost DC-DC converter circuit? What happens as you make the capacitor larger, or smaller?
There are at least two effects of decreasing the output capacitor size. Can you tell us what they are?
Why do you have this constraint? Is it coming from someone who does not have an understanding of electronics? Or is it being posed as an advanced puzzle by someone who knows of an elegant non-standard solution?
it is posed as an advanced puzzle by someone who knows of an elegant non-standard solution. It's like a challenge. so i have to find a way to do 5V with a 1.5V battery without any capacitor.
You'll need some kind of reactance, but it doesn't have to be capacitance. You can build a voltage multiplier with inductors, too -- they're just larger and heavier and more expensive.
- Warren
Couldnt you just run the motor with a 1.5v battery instead? You would get lower rpm's and power, but it would still work right? And isn't this http://en.wikipedia.org/wiki/Image:B...onventions.svg circuit a half wave rectifier?
Is the puzzle saying to run a 5V DC motor, or is it saying to get 5 Vdc?
That link does not work.
Thank you chroot for your advice it worked. And yes chaoseverlasting i could run the motor with 1.5v but it was also a question of speed.
You cannot use an actual capacitor or you can't have any appreciable capacitance in the circuit? I ask because you can be clever and use some coax as some capacitance in the circuit.
'Puzzle', 'non-standard', and 'challenge', and the fact that you have specifically not specified 'DC', just 5 V, lead me to believe that your tasker intended some kind of pulse waveform be used which is plausible w/ a motor load. You can drive the motor with some kind of 5V pulse waveform. The DC/DC boost converter (referenced above) with no output capacitor with give you a pulse waveform, and the duty cycle of the converter would control the motor speed.
  • · Replies 32 ·
  • · Replies 78 ·
  • · Replies 49 ·
  • · Replies 19 ·
