A wheel rolling on a horizontal flat or inclined surface
The discussion revolves around the behavior of a wheel rolling on both horizontal and inclined surfaces, particularly focusing on the role of friction in these scenarios. Participants explore the conditions under which friction acts on the wheel and the implications of rolling at constant velocity versus constant acceleration.
  • Conceptual clarification, Assumption checking, Mixed
  • Participants examine why a wheel experiences no friction when rolling at constant velocity on a flat surface, while questioning the presence of friction on an inclined surface. There are discussions about the necessity of static friction for rolling and the conditions under which it applies.
The conversation is ongoing, with various interpretations being explored regarding the role of friction in different scenarios. Some participants have offered insights into the mechanics of rolling and the forces at play, while others are seeking clarification on specific points related to friction on inclined planes.
There is mention of ideal cases and assumptions regarding the absence of net forces, as well as the conditions under which a wheel rolls without slipping. The discussion also touches on the complexities of friction in relation to acceleration and the angle of inclination.
Yam
A wheel rolling on a horizontal flat surface at a constant velocity experiences no friction force. Why?
A wheel rolling on an inclined surface at a constant velocity experiences friction force.
A wheel rolling on a horizontal flat surface at a constant velocity experiences no friction force. I don't quite understand why there isn't any friction, i understand that the point of contact between the wheel and the surface has a velocity of zero, so it is considered not moving and thus there isn't any friction. However, doesn't it apply to the wheel on an inclined surface?
There is certainly a static frictional force on a wheel that is rolling smoothly at a constant velocity. Otherwise it wouldn't be rolling.
AlephNumbers said:
There is certainly a static frictional force on a wheel that is rolling at a constant velocity. Otherwise it wouldn't be rolling.
I'll have to disagree with you on this one. Once the wheel is rolling there is no net force on the wheel if it rolls with constant velocity . Certainly static friction is required to get the wheel to roll, but not required once it is rolling. I am, of course, referring to an ideal case.
Yes i understand this point, but i still don't quite understand why you have friction on an inclined plane, also what kind of friction is it?
I think that just because there is no net force, that does not mean that there are no forces acting on the wheel.
Even that is not strictly true. Many aircraft pre-spin their wheels for landing to reduce wear. If they happen to get it just right, there's no frictional force needed.
It says "inclined surface at a constant velocity". How that is achieved is not stated, but whatever the means there's no acceleration. Given that gravity will have a downslope component, something must oppose that.
I made a mistake with my post.
A wheel rolling on a surface with constant acceleration experiences frictional force.
I kind of understand why.
A wheel rolling on a horizontal flat surface at a constant speed means that the wheel is pure rolling without slipping. There is no translational force present and thus there will be no friction even on the roughest surface.
On the other hand, a wheel undergoing constant acccleration means that it is undergoing up the incline with pure rolling without slipping. The maximum force of friction acting against the wheel will be mgsin(angle of incline)
Do you guys think that i am right?
If it's rolling on a horizontal surface at constant velocity there's no net horizontal force. If there's a frictional force it will be horizontal. What is going to balance that?
This got me interested. How does pre-spinnign their wheel reduce wear and tear from friction?
Actually I just checked my claim and found that this has been proposed many times, but not implemented. Seems the extra weight of the means to do it is not justified.
Yam said:
a wheel undergoing constant acceleration means that it is undergoing up the incline with pure rolling without slipping.
Couldn't parse that. You don't know whether it's uphill or down.
It may be clearer/more general to think in terms of torque. If the wheel is rolling and accelerating then it has angular acceleration. That requires a torque, and friction is the only force that has a moment about the wheel's centre.
You left out ##\mu##.
hmmm.. i don't understand, wouldn't maximum friction be when
μmgcos(angle) = mgsin(angle) ?
OK, I see - I didn't notice you put sin, not cos.
So I change my response to:
Parallel to the slope there are two forces, mgsin(angle) and friction. If there's no acceleration then they're equal and opposite. If accelerating up slope then friction must be the larger. Friction may also be the larger if accelerating downslope very fast (faster than it would slide with smooth contact).
Thanks for pointing this out! cheers!
  • · Replies 60 ·
  • · Replies 42 ·
