AA Batteries heating up during severe hail storm.
During a severe hail storm, a person experienced overheating AA batteries, which he discarded after feeling a burning sensation. The discussion suggests that the batteries likely heated up due to a short circuit, possibly caused by conductive materials in his clothing or damaged insulation on the batteries. The storm itself is considered a coincidence, as he was indoors and not exposed to moisture. The consensus is that without external factors, the batteries would not have heated up spontaneously. This incident remains a puzzling event, but the explanation revolves around electrical conductivity and potential damage to the battery insulation.
Phill123
Once during a severe hail storm (it lasted a few minutes and looked like it had snowed everywhere),
my friend starting jumping around as if something was burning him, and he pulled 2 AA batteries out of his pocket and threw them outside. They were really hot and quickly melted a hole in the hail/snow where they fell.
There was nothing in his pockets except the 2 batteries.
I thought there would be a simple science based answer to this but when I asked somebody quite knowledgeable previously I got looked at like an idiot.
I have wondered about this question on and off since it happened 10 years ago, and have never had an answer.
Maybe someone here can explain what caused these batteries to heat up?
Was it anything to do with the storm?
Thanks,
Phill
Science news on Phys.org
It could be that whatever clothing he was wearing had a high content of metals or other electrically conducting substance.
When dry the conductivity would be there but quite low, but added water could increase it a lot, this providing enough current to heat things up considerably.
Likes davenn
I forgot to mention we were indoors so he didn't get wet. He moved out the door to throw them as he didn't want to burn the carpet
there's nothing in a storm that could cause that ...
you need to look at the material and what else may have been in his pockets with the batteries
The ONLY way the batteries could have heated up is if their terminals were being shorted out
EDIT ... just noticed you said 10 yrs ago ... I suspect the story has changed somewhat
and details have been omitted / forgotten with the passage of timeDave
Thanks for the answer. I'm confident i have the details correct still,
however i agree you are most likely correct that it must have been the fabric conducting, and the storm a coincidence.
There was certainly nothing else in his pocket.
Its quite possible that the insulation on one cell was damaged and that allowed the other cell to short the first. The insulation might have been damaged by dropping the cell of similar. Its not hard to do.
I need to calculate the amount of water condensed from a DX cooling coil per hour given the size of the expansion coil (the total condensing surface area), the incoming air temperature, the amount of air flow from the fan, the BTU capacity of the compressor and the incoming air humidity. There are lots of condenser calculators around but they all need the air flow and incoming and outgoing humidity and then give a total volume of condensed water but I need more than that. The size of the...
Thread 'Why work is PdV and not (P+dP)dV in an isothermal process?'
Let's say we have a cylinder of volume V1 with a frictionless movable piston and some gas trapped inside with pressure P1 and temperature T1. On top of the piston lay some small pebbles that add weight and essentially create the pressure P1. Also the system is inside a reservoir of water that keeps its temperature constant at T1. The system is in equilibrium at V1, P1, T1. Now let's say i put another very small pebble on top of the piston (0,00001kg) and after some seconds the system...
