Absolute Max/Min of f on [0,8]
  • Thread starter Thread starter hover
    Absolute Max
The discussion revolves around finding the absolute maximum and minimum values of the function f(x) = x/(x^2 + 25) on the interval [0, 8]. Participants are analyzing the critical points and evaluating the function at specific values within the given range.
  • Participants discuss the necessity of taking derivatives to find critical points and evaluate the function at the endpoints of the interval. There are questions about the correctness of the derivative calculations and the evaluation of f at specific points. Some participants suggest graphing the function to better understand its behavior over the interval.
The discussion is ongoing, with participants providing feedback on each other's calculations and reasoning. There is recognition of potential errors in the original poster's evaluations, and some guidance is offered regarding the importance of checking values and graphing the function. Multiple interpretations of the results are being explored.
Participants are working within the constraints of the given interval [0, 8] and are questioning the validity of certain evaluations based on the critical points identified. There is an emphasis on ensuring that all relevant points within the interval are considered in determining the absolute maximum and minimum.
hover
Find the absolute maximum and absolute minimum values of f on the given interval.
f(x) = x/(x^2 + 25)
[0, 8]
taking derivatives are necessary
[tex]f(x)= \frac{x}{x^2+25}[/tex]
[tex]f'(x)= \frac{(x^2+25)-x(2x)}{(x^2+25)^2}[/tex]
[tex]f'(x)= \frac{x^2+25-2x^2}{(x^2+25)^2}[/tex]
[tex]f'(x)= \frac{-x^2+25}{(x^2+25)^2}[/tex]
[tex]f'(x)= -x^2+25=0[/tex]
[tex]25=x^2[/tex]
[tex]x=-5,5[/tex]
[tex]f(0)=0[/tex] min
[tex]f(5)=1/2[/tex] max
[tex]f(8)=8/89[/tex]
Those are my answers but i think i am wrong...
You can't cancel
[tex]{-x^2+25}[/tex]
and [tex]{(x^2+25)^2}[/tex]
b/c of the negative.
If you factor out the negative:
[tex]\frac{-(x^2-25)}{(x^2+25)^2}[/tex]
Which gives you a numerator of
[tex]{-(x+5)(x-5)}[/tex]
which are your zeros of f'(x) and you just plug those x-values of x = +/- 5 into f(x) and find your max and min.
btw, you're x-values are right, but your process is flawed.
Also, b/c of the interval, only f(5) applies from the derivative.
You will also want to graph the equation to make sure.
Graph all of f(x) and then eyeball where 0 and 8 are and just mark through them to show exactly the part of the curve with which you are dealing.
You should do this with all functions, especially rationals. A simple sketch should do the trick most of the time with a few points written in. Don't forget your asymptotes and intercepts too!
Lastly, your f(5) and f(8) values ARE WRONG. Make sure that you plugged 5 and 8 into f(x) and nothing else. Also, upon graphing, you will note that f(8) is not an absolute max or min. Compare f(0), f(5), and f(8)
f(5)=1/10
but i think f(8) is right
shouldn't that mean that f(0) is a min and f(5) is a max?
got it. the answer is correct thanks! :)
My bad, yes f(8) is right.
  • · Replies 27 ·
  • · Replies 36 ·
