Absolutely STUCK on a 2nd derivative
  • Thread starter Thread starter mateomy
    Derivative Stuck
6 replies · 2K views
mateomy
Absolutely STUCK on a 2nd derivative!
The problem is to find the second derivative of y= [tex]\sqrt{x^2+x-2}[\tex]<br /> <br /> <h2>Homework Equations</h2><br /> <br /> I know I have to use the Chain Rule and the Quotient Rule.<br /> <br /> <h2>The Attempt at a Solution</h2><br /> <br /> So, I've gotten the first derivative (checking the book) to make sure I am right...<br /> <br /> y'= [tex]\frac{\2x+1}{2\sqrt{x^2+x-2}[\tex]<br /> <br /> Moving on...I've managed to set up the 2nd as so...<br /> <br /> y''=[tex]\frac{(x^2+x-2)^2(2)-(2x+1)(1/2)(x^2+x-2)^-1/2(2x+1)}{2(x^2+x-2)^3/2}[\tex]<br /> <br /> And this is where I get stuck, because the book ends up getting something like...<br /> <br /> y''=[tex]\frac{-4x^2-4x-10}{4(x^2+x-2)^3/2}[\tex]<br /> <br /> I can't figure out how they get that in the end. When I factor out the [tex](x^2+x-2)[\tex] from the top and bottom my numerator looks waaaay off. Is it something I am doing with the factoring/canceling of the forementioned term?[/tex][/tex][/tex][/tex][/tex]
mateomy said:
The problem is to find the second derivative of y= [tex]\sqrt{x^2+x-2}[/tex]
y'= [tex]\frac{2x+1}{2\sqrt{x^2+x-2}}[/tex]
y''=[tex]\frac{(x^2+x-2)^2(2)-(2x+1)(1/2)(x^2+x-2)^-1/2(2x+1)}{2(x^2+x-2)^3/2}[/tex]
y''=[tex]\frac{-4x^2-4x-10}{4(x^2+x-2)^3/2}[/tex]
I can't figure out how they get that in the end. When I factor out the [tex](x^2+x-2)[/tex] from the top and bottom my numerator looks waaaay off. Is it something I am doing with the factoring/canceling of the forementioned term?
Fixed your latex. Remember that the right side is [/tex] not [\tex]
Thanks for that. I am reading on how to use LaTeX right now. Again, thanks.
Hello there,
here is the problem, your second derivative is wrong it should be:
y"= [2(x^2+x-2)^(1/2)-( {((2x+1)^2)/(2(x^2+x-2)^(1/2))} )] /(2(x^2+x-2))
then what you have to do is multiply by (x^2+x-2)^(1/2) both the numerator and the denominator
thus you'll obtain this form :
y" = (2(x^2+x-2)-(2x+1)^2)/(2(x^2+x-2)^(3/2))
all you have to do now is develop the numerator of this expression and you'll get this :
y" = (-2x^2-2x-5)/(2(x^2+x-2)^(3/2))
here you go, and to get the exact one like the book, u have to multiply by 2 both numerators and denominators... Your book should have done the simplification already though...
joeghal87 said:
Hello there,
Thanks, but I am still confused. Why would you want to multiply the denominator and numerator by 2? I know it will make the expression match what I have in the book, but what would be the ultimate purpose (besides and answer match) to doing the multiplication?
Super appreciative for the help, btw.
the purpose : absolutely nothing at all :) actually your book just didn't simplify the expression to the fullest... if you divide by 2 the numerator and deminator in the final expression reached from the book, you get to the one I found... like I said, they should have done the simplification themselves :)
and you're welcome ! anytime :)
Thank you so much. I've been pacing around all morning trying to figure out why that looked the way it did.
And now...on to yet more problems.
THANKS!
