AC termination power calculation
  • Thread starter Thread starter likephysics
    Ac Power
The discussion focuses on the calculation of power dissipation for AC termination on clock signals, particularly in the context of circuit design and signal integrity. Participants explore various factors influencing power dissipation, including clock frequency, signal amplitude, and capacitance, while also considering practical applications and modeling techniques.
  • Experimental/applied
  • Some participants suggest that power dissipation can be calculated using the formula ##P_d = f C \Delta V^2## under certain conditions, particularly when the rise/fall time is short compared to the RC time constant.
  • Others emphasize the importance of knowing the clock frequency, signal amplitude, and capacitance, proposing that charge is pumped through the resistor with each clock transition.
  • A few participants advocate for using simulation tools like LTspice for modeling, while others argue that simpler analytical methods can provide sufficient insight and are faster for basic calculations.
  • Concerns are raised about the complexity of AC termination, especially when used with low-power drivers, and the potential unpredictability of results when changing line lengths.
  • Some participants mention the use of AC termination in specific applications, such as DDR4 clock signals, while others caution against its use in digital data or RF signals.
There is no consensus on the best approach to calculating power dissipation for AC termination. Participants express differing opinions on the utility of simulation tools versus analytical methods, as well as varying perspectives on the appropriateness of AC termination in different contexts.
Participants note that the assumptions regarding rise/fall times, RC time constants, and the nature of the signals involved can significantly affect the calculations and outcomes discussed. Additionally, the complexity of AC termination in relation to the real characteristic impedance of transmission lines is highlighted as a consideration in sizing capacitors.
likephysics
How do we calculate power dissipation for AC termination on a clock signal?
The resistor is dissipating only at the edges(assuming a square wave).
You need to know the clock frequency, the amplitude of the signal, and the capacitance.
Charge is pumped through the resistor with each clock transition.
C = Q / V ; Q = CV .
Q = I t ;
Or you model it with LTspice etc.
If the rise/fall time of the square wave is short compared the the RC time constant, then the energy lost on each edge is the same as the energy change on the capacitor so ##P_d = f C \Delta V^2 ##
https://www.maximintegrated.com/con...snubber-power-loss-estimate-saves-the-day.pdf
PS: This assumes that either the initial voltage or the final voltage is zero. It's really ##P_d = f C |(V_1^2- V_2^2)|##. Again, the energy change in the capacitor is also the energy lost.
Nope. Not for simple circuits. This is a simple derivation which gives you some insight into what's happening. Also, precise answers are virtually never necessary, for most power calculations you're probably looking for a worst-case analysis. I can memorize this simple answer and do it on a handheld calculator about 1000x as fast as you can set up and run your simulator.
BTW, there is (at least in power supplies, where energy is greater) an interesting question about what is the applied voltage step in resonant edges with overshoot. The snubber is designed to reduce them, but also absorbs extra energy in the process, so it is sometimes (OK, rarely) a recursive problem. Again, IRL you just make a worst-case assumption and verify later.
If saving power in terminations is your only concern, then go ahead. I believe there are more critical parameters than reducing power consumption, for example, functionality and reliability.
Before I build a lower-power clock distribution system, I simulate it to identify phase shift, and the reduction in noise immunity due to Gibbs effect.
Yes, a distribution network is a great place to use simulators. But that wasn't the question here.
Baluncore said:
LTspice etc.
Ick.
That's a little unfair. Tools like LSpice have their utility for sure. But there is a whole generation of freshly minted EEs who can only seem to do Spicy things.
I'm talking about recent grads who did not recognize a big electromagnet as an inductor.
Mech E.s have a similar problem. I had one - who is extremely good - ask me what it means when the FEA said a force was negative: it means that had he build it, it would flip over.
These tools have their uses. But brains have more.
You answer the question as you interpret it.
I answer the question as I interpret it, as part of a bigger world.
Let the OP decide.
Don't tell others are wrong, because you must be right. Gaslighting members who reply, may make others feel you have a personality disorder.
I suggested a solution and the option; "Or you model it with LTspice etc."
I did not insist that be the first and only way.
Vanadium 50 said:
Ick.
You need to express yourself more clearly.
Baluncore said:
...may make others feel you have a personality disorder.
Not the first time I've heard that. LOL. Never the less, ad hominin replies aren't really kosher.
My response was intend to inform the OP and other readers that the solution to the step response of an RC circuit is something that you should learn on paper, not by asking a computer to give you the answer. You are absolutely correct, you could use LTSpice to give you a numerical answer, but I don't think that's great advice for simple problems. I'm sorry we disagree about that, but I don't think I'll take it back.
Yes, BTW, I do have a attitude problem with simulators, in spite of having used them quite a bit. They are best for things that are impossible or really difficult to calculate. Otherwise I think they get in the way of education about the foundations of circuit analysis. Perhaps the OP agrees? IDK.
likephysics said:
How do we calculate...
PS: Look up the definition of gaslighting. I'm not trying to change you.
Sorry if this question is a bit more on-topic (but not quite), but have any of you used this type of AC termination? I've only used DC forward terminations when the driver can handle the power, and back-terminations when the driver was low power. If I were going to try to use an AC forward termination with a low-power driver, I'd be worried about the complex nature of the termination vs. the real ##Z_0## of the TL. What considerations do you use in sizing the AC termination capacitor?
I guess the point is to save power for low frequency clocks (compared to the transition times)? IDK. That would be the ## RC \gg t_r ## case that I mentioned. Most want to move as much data as possible and they end up staring at curvy lines in eye diagrams.
Yes, I have used it, but only on low frequency, square-wave heartbeat clocks.
Never use it on digital data, RF signals, nor sinusoidal frequency references.
The RC termination is more of a snubber than a line termination. Changing line length in the future, leads to unpredictable results that are hard to identify.
The AC termination is used to terminate DDR4 clock. Other than this, I haven't see AC termination much.
See page 8 of this app note: https://community.nxp.com/pwmxy87654/attachments/pwmxy87654/imx-processors/188384/1/AN5097.pdf
DMM ref designs also have AC termination on the clock.
DaveE, thanks for link and the answer. I was trying to use C*V^2*f and then use 20-30% of the result to account for rise and fall time.
There's also power dissipated by the resistor during this duration, right?
Q = I t ;
I did use LTspice and learnt how to plot power, which I did not know before.
According to simulation, the Ac termination power is 10x lower than just resistor termination for the same freq, amplitude.
I find it that knowing how to do it outside simulation is the key to understanding.
This (my) stuff is all about the power dissipated in the resistor. The power loss in the driver is a much different question. Read through that link again, the RC step response should be pretty straight forward. They talk about modifications if you don't meet my ##RC \gg t_r## assumption.
  • · Replies 48 ·
9K
